Simplifying to a Geometric Series
The discussion revolves around solving a differential equation using power series, specifically focusing on simplifying the resulting series into a geometric series. The original poster has derived a recurrence relation and is attempting to identify a pattern in the coefficients of the series generated.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are exploring the relationship between coefficients and questioning the pattern of the series. There is an emphasis on systematically deriving the coefficients rather than guessing. Some participants suggest writing terms in relation to earlier coefficients to identify a pattern.
There is ongoing exploration of the series coefficients, with some participants providing insights into factorial expressions and their relationships. While there are corrections to earlier terms, no consensus has been reached on a definitive pattern or simplification method.
Participants note discrepancies in the series terms and question the completeness of the derived expressions. There is a focus on ensuring that all terms are accounted for in the series representation.
xago
I have a question with asks to solve a differential equation via power series and I've done everything up to finding the recurrence relation which is a[itex]_{n+2} = -[/itex][itex]\frac{a_{n}}{n+2}[/itex]
Given the initial conditions a[itex]_{o}[/itex] = 1 and a[itex]_{1}[/itex] = 0 I'm trying to simplify the series into a geometric series. The series is 1,-1/2, 1/8, -1/48, 1/480, -1/5760 etc...
So far I've gotten (-1)[itex]^{n}[/itex] in the numerator to account for the alternating negative sign, however I can't find the denominator for the life of me...
my best attempt is [itex]\frac{(-1)^{n}}{(2^n)}[/itex] but it only works for the first 2 terms :S
Don't just try to randomly guess what the pattern is by looking at the first few terms. You want to try to do it a little more systematically than that. Try to write [itex]a_{n+2}[/itex] in terms of [itex]a_0[/itex] (hopefully you noticed that all the odd coefficients are zero).
i.e., start writing
[tex]a_{2k+2} = -\frac{a_{2k}}{2k+2} = (-1)^2\frac{a_{2k-2}}{(2k+2)(2k)} = (-1)^3\frac{a_{2k-4}}{(2k+2)(2k)(2k-2)} = \dots[/tex]
and then see if you can guess a pattern that gives [itex]a_{2k+2} = a_0/(\mbox{stuff})[/itex]. (note that I set n = 2k).
Once you figure out the pattern, if you want to legitimately prove it's correct you can prove it using induction (i.e., prove it holds for k = 1, then prove that if you assume the form is true for k it follows that it's true for k+1).
Also, note that the terms in a geometric series have the form [itex]ar^k[/itex]. Your terms won't look quite like this, so it's not exactly a geometric series.
The best I can do is 2k! which gives 2k(2k-2)(2k-4)...right? it works up k=3 to but it's missing the 2k+2 term and doesn't work for k=4
I know 2k! is expressed as [itex]2^{k}[/itex]k! but how is (2k+2)! expressed in such a way that I can calculate it?
edit*
oops, 2k! is right I believe. I miscalculated the series in my first post, instead of -1/48, 1/480 it should have been -1/48, 1/384 etc..
Looks like 1/480 should be 1/384 instead, and 1/5760 be 1/3840. Did you skip a term?
In any case, you might want to check out Sloan's Sequences: https://oeis.org/
If you're still not sure, just take (2k)! and replace k with k + 1: (2(k+1))! = (2k+2)! = 2k+1(k+1)!, such that
[tex]a_{2k+2} = \frac{(-1)^{k+1}}{2^{k+1}(k+1)!}[/tex]
(2k+2)!= (2(k+1))! so it would just be [itex]2^{k+1}(k+1)![/itex]
edit*
