Simplistic fluid heat loss - water in a concrete tank
The discussion centers on heat loss calculations for a basement swimming pool constructed with waterproof concrete, where insulation was not applied externally. The user, Rob, established that the thermal conductivity of insulated concrete is approximately ten times lower than that of uninsulated concrete. Consequently, Rob concluded that the annual energy cost for maintaining the pool without insulation would be around £3000, compared to £300 with insulation, making insulation the clear choice for energy efficiency.
  • Understanding of thermal conductivity principles
  • Familiarity with R-value calculations
  • Knowledge of BTU (British Thermal Unit) measurements
  • Basic geometry for calculating surface area and volume
  • Research thermal conductivity of various insulation materials
  • Learn how to calculate R-values for different construction materials
  • Explore energy cost estimation techniques for heating pools
  • Investigate methods for insulating concrete structures effectively
Homeowners, pool builders, energy efficiency consultants, and anyone involved in construction or renovation projects requiring thermal management solutions.
sanderr2
Hi all,
I'm sorry if this is an inappropriate question. I have built a basement swimming pool for my wife. Unfortunately I neglected to insulate outside the concrete and insulating inside the concrete has caused some construction issues so I am trying to work out the heat loss if I go ahead without insulation.
I know the approximate ground temperature outside the concrete box.
I can establish an R value for the waterproof concrete.
I know the dimensions i.e. the surface area of the pool walls / bottom and the volume of water.
The heat loss from the pool surface will presumably be the same whether I insulate the pool or not so can be disregarded for the comparison.
Is there an equation that I can plug my values into so see how many BTU I will have to put in with and without insulation so I can establish how much not insulating is going to cost me in energy terms?
Humble thanks in anticipation,
Rob
Hi - no need for anyone to reply. I've realized that the thermal conductivity of insulated is about 10x lower so whatever the cost, the energy required will presumably be about 10x the amount so insulated. I think this equates to an annual cost of £3000 vs £300 so it's a no brainer. Insulated it has to be... Rob
PS Couldn't find a way to delete my thread!
  • · Replies 16 ·
