Simulation of beta-binomial distribution
The discussion revolves around the simulation of a beta-binomial distribution, where the user is attempting to model the number of successes in N Bernoulli trials with varying probabilities that follow a beta distribution. The user initially generates a constant vector of beta-distributed probabilities for each trial but finds that the resulting PMF does not fit the expected beta-binomial distribution. Suggestions include using a probability generating function to accommodate the independent events with different probabilities. Ultimately, it is clarified that knowing the probabilities of success makes the scenario fit a Poisson-binomial distribution rather than a beta-binomial distribution. The user is encouraged to reconsider their approach based on this understanding.
fchopin
Hi all!
I'm trying to solve the following problem.
The number of successes in a sequence of N yes/no experiments (i.e., N Bernoulli trials), each of which yields success with probability p, is given by the well-known binomial distribution. This is true if the success probability p is constant and the same for all the N trials.
However, when the probability of success, p, is different for each trial, p_1, p_2, ..., p_N, then the number of successes does not follow a binomial distribution, but a Poisson's binomial distribution instead:
wikipedia--> /Poisson_binomial_distribution
I understand that the Poisson's binomial distribution is valid for any set of probabilities p_1, p_2, ..., p_N.
In my problem, I know that the probabilities p_1, p_2, ..., p_N follow a beta distribution. I found out that, in such a case, the resulting PMF of the number of successes in N trials is given by the beta-binomial distribution:
wikipedia --> /Beta-binomial_distribution
However, I have been playing a bit with some simulation and it seems that this distribution does not fit the resulting PMF. I'm attaching a Matlab file that makes some simulation and generates the PMFs.
What am I doing wrong? Is it possible to exploit the knowledge that the p_1, p_2, ..., p_N follow a beta distribution to simply the general Poison's binomial case? What is the PMF that I need?
Many thanks in advance!
Fryderyk C.
I don't know matlab. Did you draw a new value of p on each bernoulli trial? You comment says you intended to, but I don't see where this happened inside your loop on t.
Thanks for quick reply.
Basically my problem is that I have a set of N "things" I observe at different time instants t, and I know the success/failure probabilities for each "thing". What I need is the probability to observe k successes in each observation of the N "things".
So I first generate a vector p with N beta-distributed random numbers --> p = betarnd(a,b,1,N), which remains always the same.
Then I use the same set of probabilities p = p_1, p_2,...,p_N in every iteration of the loop on t.
In the problem I'm studying, the N values of p are known and constant. I thought this might be the reason why the beta-binomial distribution doesn't fit. However, I tried drawing different values of p in every iteration of the loop on t and the result doesn't fit the beta-binomial distribution either. In this case, even the Poisson's binomial distribution doesn't fit! Any ideas? Thanks!
If you have independent events for each 'thing' but the probabilities for each thing is different, then you can use what is called a probability generating function to generate the distribution even if each thing has a different probability.
http://en.wikipedia.org/wiki/Probability-generating_function
I don't think your description fits the Beta-Binomial distribution but rather the Poisson-Binomial distribution, the moment you know the probability of success of your event within a period t it is irrelevant if you know it because X follows a Beta distribution or any other, the fact is that you know it.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
