Simultaneously Solve a Linear and Cubic equation
  • Thread starter Thread starter bartrocs
    Cubic Linear
7 replies · 10K views
bartrocs
Solve the following equations Simultaneously:
y=x^3 and y=3x-2
My question is, how do I solve this? I've tried everything
I've tried to isolate x in the linear equation and substitute it into the cubic. I don't know if that's wrong but it didn't work for me. This is what I did:
isolate x in linear equation: x= -2/3-y/3
substitute this into cubic equation: y=(-2/3-y/3)^3
I then expanded this and it didn't work.
I also tried: 3x-2=x^3
therefore: x^3-3x+2=0
this didn't work either! please help!
This way is a good start; do you know about the rational root theorem?
By inspection, there is at least one integer solution between 0 and 2 to the two equations.
There is also another integer solution between -3 and -1.
I would prefer you told me the methods for solving the equations rather than the answer. I already know the answer by using my graphics calculator. However this is of no use to me as I want to solve it the proper way without a calculator.
I didn't. But I Googled it and I do know now. Is there any way to do these simultaneously like you can with a quadratic and linear equation?
Try to group the terms so as something can be factor out.
x3-3x-2=(x3-x)-2(x-1).
The rational root theorem is also very useful. It states: For a polynomial equation
anxn+an-1xn-1+...a0=0,
if p is an integer factor of the constant term a0, and q is an integer factor of the leading coefficient an, the rational solution is of the form ±p/q.
In this case, a3=1 and a0=-2, so q=1, and the possible p values are 1 and 2. So you have 4 possible values for x to try if they are roots or not. If one of them (x1) is a root, you can divide the equation by the factor of (x-x1) and you get a quadratic equation to solve.
ehild
Believe it or not, inspection is actually the first thing you should always try when given a problem like this. Inspection is an entirely proper technique.
There is some meta-reasoning involved. They can't actually want to make you solve a random cubic, since that would be too difficult. There might be a simple solution. So you mentally plug in the simplest numbers ... 0, 1, -1, 2, etc. And if you do this, you find a solution.
Once you have one solution, you can do a polynomial division to reduce the cubic to a quadratic, which you know how to solve using the quadratic formula.
So even though there are a few more technical things you can and should try; the very first thing you should do is plug in the most obvious simple numbers and see if a solution pops out.
That last expression can be easily factorised into 3 linear factors, and I am sure that was supposed to be the next step in the solution.
I can see that x=1 will make the LHS = 0, so x=1 is a solution.
Now, take out the factor (x-1).
In your working for this, you divide x3-3x+2 by (x-1)
