Simultaneously unitarily diagonalizeable matrices commute
  • Thread starter Thread starter bmanbs2
    Commute Matrices
Matrices A and B are simultaneously unitarily diagonalizable, implying the existence of a unitary matrix P such that P^{-1}AP = D_{1} and P^{-1}BP = D_{2}, where D_{1} and D_{2} are diagonal matrices. Since diagonal matrices commute, it follows that D_{1}D_{2} = D_{2}D_{1}. The discussion highlights the necessity of proving that A and B are normal to utilize the unitary property effectively. A user seeks clarification on whether their current proof is sufficient to demonstrate that AB = BA. The conversation emphasizes the connection between simultaneous diagonalizability and the commutativity of matrices.
bmanbs2
Matrices A and B are simultaneously unitarily diagonalizeable. Prove that they commute.
As A and B are simultaneously unitarily diagonalizeable, there exists a unitary matrix P such that
P^{-1}AP = D_{1} and P^{-1}BP = D_{2}, where D_{1} and D_{2} are diagonal matrices., where D_{1} and D_{2} are diagonal matrices.
Diagonal matrices always commute.
A unitary matrix multiplied by its conjugate transpose results in an identity matrix.
So far I have that
P^{-1}APP^{-1}BP = P^{-1}ABP = D_{1}D_{2} and
P^{-1}BPP^{-1}AP = P^{-1}BAP = D_{2}D_{1}
D_{1}D_{2} = D_{2}D_{1} P^{-1}ABP = P^{-1}BAP.
Is this enough to show that AB = BA? Where would I use the fact that P is unitary?
Also, how do I delete the latex part at the top? It goes straight to the first latex entry. I put empty tex tags at the top to make it as non-distracting as possible, but if I don't add them, the gibberish goes straight to the next latex section.
Bump?
you don't need the unitary part, since two diagonalizable matrices are generally simutaneously diagonalizable if and only if they commute; the unitary part is needed if you also assert that the matrices are both normal -- did you leave that out?
I didn't, but I just recieven an update to the assignment that says I need to show the matrices are normal.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
  • · Replies 33 ·
12K
