Undergrad Single vs. Double slit coherence clarification please
  • Thread starter Thread starter PhysicsIsReallyFun
The discussion centers on a video where a woman claims the double slit experiment is misunderstood, asserting that detecting electrons does not cause decoherence and that the electron wave passes through only one slit. Critics argue that any detection is indeed associated with decoherence, and her interpretations of wave-particle duality are flawed. There is skepticism about her qualifications to challenge established quantum mechanics concepts, especially as she fails to comprehensively compare electrons and photons. Additionally, there are concerns regarding the accuracy of popular physics explanations, particularly those by physicist Jim Al-Khalili, who allegedly denies single-slit diffraction for electrons. Overall, the conversation highlights confusion and misinformation surrounding quantum mechanics and the interpretation of experimental results.
PhysicsIsReallyFun
TL;DR
Single slit electron detection - Is wave nature still observed?
The woman in the video below is claiming everyone has the double slit experiment wrong. She is claiming that when electrons are detected as they pass through the slits decoherence does not occur, what is happening is that the electron wave only passes through one of the slits.
Her "proof" is that if you detect the electrons in the double slit experiment the result is not two bands of particles on the screen behind the slits but rather two diffraction produced interference patterns.
We can simplify this experiment to a single slit. If electrons are directed through a single slit a slight interference pattern is produced due to the electron wave diffracting through the opening. I had thought that if a detector was used the electron wave would disappear and the result would be electron particles and no interference pattern observed due to diffraction?
She seems to know what she is talking about and now has me confused?
Specifically at 9:00 in the video.
She says that when you have a detector before both of the slits, this "forces the electron to collapse to just one of these (waves) and you see a single slit interference pattern."
Is this the biggest lie in physics as her video title claims or is she greatly mistaken, to put it nicely?
That is certainly wrong. Any detection is associated with decoherence.
Likes sophiecentaur
You have to ask yourself whether a single Physics PhD graduate really understands QM better than everyone else? It's not a credible claim.
PS that said, I watched Jim Al-Khalili's lecture on QM at the Royal Institution and he strongly implied that there was no wave-like behaviour for a single-slit (i.e. no diffraction); but only wave-like behaviour when there were two slits. I emailed him about this, but didn't get a reply.
She is correct that this misinformation is widespread. And, bizarrely, is promoted even by physicists who should know better.
Likes sophiecentaur
She is unhappy with the way popularizers use the double slit experiment to illustrate wave-particle duality. She seems to try to better understand the meaning of wave-particle duality for herself, and those oversimplified depictions of the double slit experiment are not helpful for her.
However, her own attempts to make sense of wave-particle duality are on the wrong track, in my opinion. As long as she doesn't understand in which situations (classical) light acts like a particle, and in which sense, she will have an extremely hard time "investigating" whether electrons act more particle-like than light or not.
One such situation is depicted on the (last) slide Coherence Time and Coherence Length. For "sufficiently" short coherence length, light starts to act particle-like. One can build lasers with extremely long coherence length, so this particle-like behavior can be suppressed (for light). But lasers exploit the fact that photons are bosons, so this won't work for electrons. Of course, electron wavepackets still have a finite extent, but the point particle picture has always been an idealization, even in classical mechanics.
No, that is not really what she tries to convey. Her point is rather that the wave-like behavior is still there.
Likes PeroK and Motore
This is the filter that we should always apply. Her video is a bit 'superficial' / arguable, I think. I am skeptical about the idea of using Youtube videos to publish theories. It's a very cheap and cheerfull medium and relies on equally cheap and cheerful comments to justify or debunk the ideas. Otoh, if you post on PF, you can rapidly be put back in your place by 'peer' reaction.
She doesn't do a comprehensive comparison between electrons and photons. For a start, she uses the term "interaction" to link the patterns from her ripple tank simulator with the light wave situation. EM waves do not 'interact'. There is only apparent 'interaction' between the pairs of waves over the whole distance when there is 'measurement / detection everywhere but that's not interaction, it's just what the detector array would see. If you were to do the (long winded) two slit experiment with electrons over a range of distances, you would get the same pattern (2D this time) as the ripple tank.
She implies a dichotomy with regard to coherence although it seems to me that the only reason for any apparent difference is method of detection of the presence of either particle as it goes past. Any change of coherence could be due to the measurement method.
I was a bit disappointed to learn that Jim Al-Kalili denies diffraction of single slit electron. I wonder if this has been reported accurately? Electrons are far less frequently measured than photons but, afaiaa patterns are uncannily similar but not in scale. An electron microscope uses much shorter wavelengths but the fine structures produce diffraction patterns. Why ever would a single hole be different?
You can check out his video here. The single versus double-slit experiment starts at 2:40, approximately:
I would say it's at best highly misleading regarding the importance of the width of the slits (which determines the amount of diffraction). This strongly implies that it's the number of slits that deternmines the wave-like behaviour; rather than the width of the slit - with interference being a function of the two diffraction patterns.
Likes sophiecentaur
Yes; very highly misleading. The arm waving description of what goes on as the slit gets narrower omits the fact that the pattern will be sinx/x (measured). Mr. Al-Kalili; the numbers count!!!
Likes Delta Prime
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 36 ·
  • · Replies 26 ·
  • · Replies 60 ·
