What is the velocity of gasoline in a siphon tube after opening?
  • Thread starter Thread starter smillphysics
    Gas Velocity
The discussion revolves around determining the velocity of gasoline in a siphon tube after it is opened. The problem involves fluid dynamics principles, specifically applying Bernoulli's equation to a siphon system with given dimensions and properties of gasoline.
  • The original poster attempts to apply Bernoulli's equation but questions the accuracy of their height measurements and calculations. Other participants inquire about the correct height to use for the pressure calculations and suggest that the pressure at both points in the tube should be considered equal.
Participants are actively engaging with the problem, raising questions about the assumptions made regarding height and pressure. Some guidance has been offered regarding the pressure at different heights, but there is no explicit consensus on the correct approach or resolution of the issue.
There is uncertainty regarding the correct height to use in the calculations, as well as the implications of the tube's shape and pressure consistency. Participants are also navigating the constraints of homework rules that may limit the information they can share or receive.
smillphysics
A siphon tube is filled with gasoline and closed at each end. One end is inserted into a gasoline tank 0.20 m below the surface of the gasoline. The outlet is placed outside the tank at a distance 0.45 m below the surface of the gasoline. The tube has an inner cross-sectional area of 3.8 × 10-4 m2. The density of gasoline is 680 kg/m3. Ignoring viscous effects, what is the velocity of the gasoline in the tube shortly after the tube is opened?
P1+.5*rho*v1^2+rho*g*y1=P2+.5*rho*v2^2+rho*g*y2
1 atm = 1.05E5
So I plugged in 1.05E5+0 (because v at top=0)+680*9.8*-.2 = 1.05E5+.5*680*v2^2+680*9.8*-.44
Completing this calculation gives v2= 2.17m/s which is incorrect. Any suggestions on what I am doing wrong?
And to find the flow rate I would use the equation Q=Av and use the provided area given with the v discovered?
Hi smillphysics! :smile:
(have a rho: ρ and try using the X2 tag just above the Reply box :wink:)
smillphysics said:
… because v at top=0)+680*9.8*-.2 …
but -.2 isn't the height at the top :wink:
Yup! :biggrin:
What is the height at the top? I then tried to put .45-.2=.25 and used that as the height at the top but that is also incorrect.
Any help on this would be great- I can't seem to find the correct y1 to use.
(Sorry I didn't reply earlier :redface:)
y1 is at the surface
it doesn't matter where the top of the tube is, or what shape it is, the pressure at each height is the same. :wink:
I've used the same pressure at both points. I still don't know where I have gone wrong?
27K
12K
10K
