High School Size of Bullet Hole: Comparing 0.000001c & .9c
  • Thread starter Thread starter sqljunkey
    Bullet Hole
The discussion centers on the size of bullet holes created by two bullets traveling at different speeds, 0.000001c and 0.9c, through a tin foil target. Participants agree that the holes would be the same size, as the diameter of the bullets does not change due to length contraction when traveling perpendicular to the target. Some debate whether the target's motion could affect the hole's shape, but the consensus remains that under the assumptions of general relativity or special relativity, the holes would not differ in size. The conversation highlights the complexities of modeling such scenarios, suggesting that advanced computational resources would be necessary for a more detailed analysis. Ultimately, the thread concludes that the initial question has been adequately addressed.
sqljunkey
If I had two bullets one moving 0.000001 c and the other moving at .9 c for example, and they both went thru a tin foil square target, assuming they are traveling in vacuum, and that the tin foil square target will make a perfect aperture around the radius of the passing bullet, assuming the bullet is cylindrical in shape, which bullet hole would be the bigger one?
Here I'm assuming there are only two objects (with masses) in the spacetime, and I'm assuming that the principles of general relativity apply.
The holes would be the same size.
sqljunkey said:
If I had two bullets...
Are you trying to ask whether the diameter of the bullet changes? If so, the answer is no. Length contraction is along the direction of movement.
As long as the bullets are traveling perpendicular to the target, the holes should be the same size.
Good point, but is this restriction the correct one? Isn't the requirement that the target have no component of velocity perpendicular to that of the bullet? If that is not the case then the bullet hole would be elongated slightly due to the lateral motion - and this would depend on the length of the bullet in the rest frame of the foil.
Or am I misreading you?
He says GR, not SR. As such, I have no idea what he's getting at.
If you are trying to actually model this scenario as the bullet and the foil having enough stress-energy to curve spacetime, sorry, that's way beyond what we can do here. You need a supercomputer and a lot of time.
If you really meant special relativity, i.e., you are fine with spacetime being flat and you are just asking what the Lorentz transformation says about your question, you already have been given the answer in this thread.
In either case, it is time to close this thread.
  • · Replies 50 ·
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 36 ·
15K
  • · Replies 29 ·
