Slipping transitioning to rolling without slipping
The discussion focuses on solving a physics problem involving a solid spherical ball transitioning from slipping to rolling without slipping. The ball, with a mass of 0.75 kg and a radius of 5.0 cm, experiences kinetic friction characterized by the coefficient μ. After 0.76 seconds, it achieves an angular speed of 120 rad/s while rolling up a ramp of height 16 cm. The key to solving for μ lies in applying angular impulse, as the initial and final angular speeds are provided, simplifying the analysis without needing to determine the initial linear velocity.
  • Understanding of rotational dynamics and angular impulse
  • Familiarity with the concepts of kinetic friction and its coefficient
  • Knowledge of conservation of energy principles in mechanics
  • Basic proficiency in kinematic equations and their applications
  • Study the principles of angular impulse and its applications in rotational motion
  • Explore the relationship between linear and angular velocities in rolling motion
  • Learn about the conservation of energy in mechanical systems, particularly in rolling objects
  • Investigate the effects of different coefficients of friction on motion dynamics
Students of physics, particularly those studying mechanics, as well as educators and anyone interested in understanding the dynamics of rolling motion and frictional forces.
lightofthemoon
A solid spherical ball of mass 0.75 kg and radius 5.0 cm is thrown onto a horizontal surface with coefficient of kinetic friction μ . It’s initial velocity at time t = 0 is horizontal and its initial angular velocity is zero. After rolling with slipping for a time t1 = 0.76 seconds, the ball begins to roll without slipping with angular speed ω1 = 120 rad/s. It continues to roll without slipping up a short ramp of height h = 16 cm
What is the value of μ?
KE = .5mv^2 = 5Iω^2
f= μN
T=Fr=Iα
vf=vi +at
I was thinking about solving this problem with conservation of energy.
.5mv^2 + .5Iω^2 - μmgd = .5mv^2 + .5Iω^2
However, we don't know the initial velocity, or the distance that the ball traveled with slipping.
In order to solve for initial velocity I thought about using one of the four kinematic equations. However, for each of the equations where are at least 2 unknowns.
So I also tried using forces to solve this problem as well.
Acceleration due to friction
f= μN
ma= μN
a=μg
Rotational acceleration
T=Fr=Iα
α= 5μg / 2r
Then I'd use the equation vf=vi +at and it's rotational equivalent. But this is where I'm stuck again, because there are also 2 unknown variables.
Since you're given the time, try using impulse.
I don't really understand.
Impulse= change in momentum = Ft
momentum = mv, so don't I still have to find the initial velocity as well as μ?
Consider angular impulse.
Oh, I see how to do the problem
But why don't I have to consider linear impulse as well since the ball is also traveling linearly?
Good!
Since you happen to be given the initial and final angular speed of the ball, using angular impulse is the most straightforward approach. And it's all you need. (You can then calculate the initial velocity, if you like.)
Oh, ok. Thanks for your help! :smile:
  • · Replies 21 ·
  • · Replies 42 ·
  • · Replies 60 ·
  • · Replies 17 ·
  • · Replies 18 ·
