Can a Palladium Foam Parachute Slow Down a Spaceship Traveling at 0.4c?
  • Thread starter Thread starter AllanR
    Spaceship
The discussion centers on the feasibility of using a palladium foam parachute to decelerate a medium-sized spaceship, approximately 1500 tons, traveling at 0.4c. The parachute aims to utilize drag from the interstellar medium to achieve a small deceleration of about one percent per year. Key considerations include the parachute's area, thickness, and mass, with suggestions that it should be maximized in area while minimizing thickness and mass, potentially resembling a solar sail in engineering design.
  • Understanding of relativistic physics, particularly concepts related to high-speed travel.
  • Knowledge of materials science, specifically properties of palladium foam.
  • Familiarity with the dynamics of the interstellar medium and its density.
  • Basic principles of drag and momentum transfer in space environments.
  • Research the properties and applications of palladium foam in aerospace engineering.
  • Explore the design and functionality of solar sails for spacecraft propulsion.
  • Investigate the dynamics of the interstellar medium and its impact on spacecraft design.
  • Learn about momentum transfer techniques in space travel and their engineering implications.
Aerospace engineers, physicists, and space mission planners interested in innovative deceleration methods for high-speed spacecraft.
AllanR
Ship is traveling at .4c.
It is medium sized, about 1500 tons displacement.
One way I want to slow down is using a parachute of sorts to use the drag from the interstellar medium. This doesn't have to be the majority of the deceleration, just a small part. A percent a year is fine.
What I was thinking making it from palladium foam. The idea is to catch the hydrogen and with a momentum transferring tether, slow the ship. I'm thinking the chute would be out for years and cover a very large area. (it might have to be brought in periodically to flush the hydrogen ).
How large would something like this be, in area and thickness? And how massive as well? Is palladium foam a plausible material?
Hello. Density and mass of interstellar medium are given, we can do estimation any way.
I think you would probably find a better engineering analogy with a solar sail.
Maximum area, minimum thickness, minimum mass. You're not trapping the interstellar medium; you're just stealing its inertia and then letting it go. There's no reason for it to be thicker than a handful of micrometers.
  • · Replies 82 ·
28K
