High School Smallest number whose sin(x) in radian and degrees is equal?
The discussion centers on finding the smallest positive real number x such that sin(x degrees) equals sin(x radians). Participants explore methods to solve the equation sin(x) = sin(xπ/180), suggesting graphing the functions to identify intersections. The first non-zero solution is estimated to occur just before x = π, with further refinement yielding an approximate solution of x = π - π²/180. The conversation highlights the cleverness of various approaches, particularly one by a user named Svein, which leads to an exact solution through a linear equation. Ultimately, the problem emphasizes the relationship between sine functions in different units and the importance of analytical versus numerical methods in finding solutions.
Phys12
Question: what is the smallest positive real number x with the property that the sine of x degrees is equal to the sine of x radian?
My try: 0.
But zero isn't a positive number. How do I even begin to solve it? I tried taking inverse on both sides of sin(theta)=sin(x), but that didn't help.
Mathematics news on Phys.org
It works, but first you have to figure out where approximately your solution is (did you make a sketch?), and express theta in terms of x or vice versa.
Do you know how to transform degrees in radiant and vice versa?
Yeah.
Phys12 said:
Yeah.
Then write it down. Put a sin before both, recognize that the sin could be canceled by a arcsin and your answer should pop up.
What you are asking for is a non-zero solution ## \sin(x)=\sin(x \pi/180) ## where the ## \sin ## function in both cases now acts on radians. Suggest you graph y vs. x for both and see where they intersect.
Likes physics user1 and Phys12
Got it, thanks! :)
Likes Charles Link
Phys12 said:
Got it, thanks! :)
Because the first function is cycling at a rate of almost 60 times the second function, the first nonzero intersection is going to occur near (just before) ## x=\pi ##. The reason is the second function is going up very slowly and the first one has made it back down to zero already. If you let ## x=\pi-\Delta ##, you can use trig identities and Taylor series. (## \theta=(\pi-\Delta)\pi/180 ## is small so that e.g. ## \sin(\theta)=\theta ## approximately.) This gives ## \sin(\pi-\Delta)= \sin(\Delta)=\Delta=(\pi- \Delta )\pi /180 ## which gives ## \Delta=\pi^2/180 ## (approximately) so that ## x=\pi- \pi^2/180 ## is a good approximate solution for ## x ##. Further refinement could be done with higher order terms or by plugging into a calculator near this point.
To spell it out: You seek the values of x, where \sin(x)=\sin(\frac{x\cdot \pi}{180}), x>0. One set of solutions is, of course x=\frac{x\cdot\pi}{180}+2n\pi, the least solution given by n=1: x=\frac{360\cdot\pi}{180-\pi}.
Another set of solutions is given by x=\pi-\frac{x\cdot\pi}{180}+2n\pi. Here the smallest solution is given by n=0: x=\pi-\frac{x\cdot\pi}{180}, or x=\frac{180\cdot\pi}{180+\pi}. This solution is the smallest value for x.
Likes Charles Link
Why approximating better than "a bit below pi", if the analytic solution can be found by solving a linear equation?
Svein's solution(s) are rather clever=I totally overlooked them. In reading them, I wasn't surprised that his first one doesn't pick up the smallest value for x, but rather picks up the intersection near ## x=2 \pi ##. His second one gets the exact answer by solving a linear equation, but without knowing that the first one did not get the answer near ## x=\pi ##, that set of solutions could easily be overlooked. I did not expect an exact answer to this one. Very good solution by @Svein. ...editing... In post #8, had I kept the next term when I solved for ## \Delta ##, I would have had the exact solution (given by Svein) without even knowing that it was the exact answer...
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 29 ·
