Smart Materials: Liquid to Solid Transformation
  • Thread starter Thread starter Total_Damage
    Materials
4 replies · 3K views
Total_Damage
Is there any material which could change from liquid state to solid state after appiled some force?
:smile:
a shear thickening fluid (approximately) may serve your purpose. Its viscosity increases considerably when stressed. Best example is a wheat flour dough. Initially it has low viscosity but as you start applying force to make is uniform it becomes more viscous.
Density wise I can't think of an example (density increasing considerably with applied stress) in semi solid and solid materials.
In fact corn starch suspension is a very good shear thickening liquid (much better than wheat though), for example you can run over it, but if you walk slowly you will sink: see demo here.
Thank you Very Much Mr.Alkim,Mr.pukb,Mr.mfb. :shy:
Now I got an idea, how to make it... really super video alkim. another thing I want to know that, Is this fluid acts as a Bullet proof?. I mean it will withstand the deformation of the pointed bullet penetration.
And too this one if the penetration made by the projectile will heals itself? Like self Haling Structure...
:confused:
Actually my target is 18mm thickness, I just want to make the target into low penetration material. is that possible by making layer of metal and Non Newtonian fluid to avoid penetration? if I'm using RHA is a target means 3 layers of RHA with 3mm thickness and 3 layers of Non Newtonian fluid with 3mm thickness. the arrangement is like layer by layer, first RHA, then Non Newtonian. this one is my need? is that possible?
