Smoke Alarms and radiation from them
  • Context: Undergrad
  • Thread starter Thread starter Happy Days2021
    Radiation Smoke
45 replies · 6K views
Some of you guys must think we live in a perfect world when it comes to handling dangerous radioactive material like americium.
In this piece from 2017, Lyman writes about some Japanese nuclear workers who were accidentally exposed to high levels of "extremely hazardous" plutonium-239 and americium-241...
https://allthingsnuclear.org/elyman...1 was present as,of the isotope plutonium-241.
The most heavily exposed worker inhaled about 360,000 becquerels (Bq) of plutonium-239, and 220 Bq of americium-241.
As he states, "The mass equivalent of 360,000 Bq of Pu-239 is about 150 micrograms."
150 micrograms is just 0.00015 grams.
In other words, if inhaled, incredibly tiny amounts of radioactive alpha-particle-emitters like plutonium-239 and americium-241 are sufficient to eventually cause a fatal cancer.
Now, does anyone seriously believe that these ionization smoke detectors can be manufactured by humans in facilities that are so perfect and pristine that there is absolutely no chance that this "extremely hazardous" americium could contaminate the plastic housing, any other part of the device, or even possibly get on packaging material?
Perhaps smoke detectors should come with a warning label that says you shouldn't grind them up and smoke them?
It doesn't need to be just less than "perfect". It would take real effort to get cancer from smoke detectors(if even possible - looks like the dose from that accident was like 50,000x what is in a smoke detector).
You're really not listening and actually analyzing risk, but instead still making scary sounding false equivalences. The amount those workers were exposed to is vastly more than you could get from a smoke detector yet still only a "maybe" cancer risk.
[Edit] Ok, I'm barely trying, but if my math serves me: if you're a pack a day smoker and you roll your own cigarettes you could disassemble and grind up the Am source from one smoke detector in each cigarette to get the equivalent dose those workers got in about four years. Not including the radiation dose from the tobacco itself, which is of a similar order of magnitude.
  • Haha
  • Love
I handle ( with respect) material much more radioactive than those tiny Americium samples in S.A's
one of my latest mineral samples is Torbernite Cu(UO₂)₂(PO₄)₂ · 8-12 H₂O
My Geiger count goes absolutely berserk in the presence of this mineral sample
not my sample ... am not at home at the moment to retrieve my photo
this one looks pretty much like my samplecheers
Dave
https://allthingsnuclear.org/elyman/cancer-risk-for-japanese-exposed-to-plutonium/#:~:text=For isotopes such as plutonium,will cause a fatal cancer.&text=Americium-241 was present as,of the isotope plutonium-241.
Im sure your laptop/desktop gives off more harmful things, than a smoke detector. Are you dying after typing? No. So relax a bit...
I'm not concerned, for two reasons. First, because the different components of the smoke detectors are manufactured in entirely different plants and are then shipped to where they will be assembled. There is simply no way for contamination to occur to such an extent as you are worried about because the components are never in a situation where that could happen.
In addition, the americium is itself mixed with gold, which is then plated with layers of gold and silver, to form a small piece of 'foil' that has two 5mm discs cut out that are inserted into the detector casing or circuit board. Alloying the americium with gold virtually assures that a person won't get contaminated, as gold is an extremely malleable metal that is very difficult to fracture by accident. It doesn't shatter into many tiny shards or turn into some sort of powder that can easily be inhaled. It doesn't corrode either, so you don't have to worry about corrosion products containing americium. In a fire the alloy melts, but the temperature is usually too low to boil the alloy or either of its constituent elements, so there is little danger of inhalation. And, assuming that the fire was hot enough to boil the alloy, if you're so close to a boiling piece of this gold-americium foil from a smoke detector to inhale any of it then you're likely in the middle of a massive house fire and are already dead.
You'd have to make a conscious and determined effort to turn these 5mm discs of gold-americium foil into something that could actually harm you. Even eating it wouldn't kill you.
My smoke detector has a sticker that says, "Do not ingest."
In addition to the radiation, the ordinary chemistry strongly influences the hazards of different substances.
  • Strontium 90 is attracted to bone structures.
  • Plutonium sinters, creating tiny particles that can get lodged in the lungs.
  • Tritium can become part of a water molecule. Our bodies are 70% water.
  • Cobalt is brilliant blue. Children have been attracted to rubbing it on their skin.
The materials used in smoke detectors do not have unique biochemical hazards.
Bizarre reply
I'm not aware of any radioactive alpha-particle-emitters in or on my desktop computer that I could inhale and that would irradiate my bone tissue for years and decades.
Yes, in the piece that I linked on Page 1, Lyman mentioned that "...impacts depend on the exact composition of the radioactive materials, their chemical forms, and the sizes of the particles that were inhaled..."
But he also said this about plutonium and americium -- "This incident is a reminder of the extremely hazardous nature of these materials, especially when they are inhaled, and illustrates why they require such stringent procedures when they are stored and processed."
Lyman probably knows more about radiation than anyone on here.
Thanks for the detailed reply to the question, and I hear what you're saying.
But here's the issue when dealing with an "extremely hazardous" material like americium -- there is no room for error.
As Lyman showed, the Japanese worker who inhaled a microscopic ("about 150 micrograms") amount of plutonium will almost certainly develop a fatal cancer.
That said, you are confident that manufacturers of these "foils", or of complete ionization chambers can police themselves when it comes to detecting possible microscopic amounts of americium that could contaminate their products?
Do you know if these products are checked for contamination when they're received at the "assembly" plants?
Do NRC or independent inspectors ever get involved at any point in the process?
Heck, I can probably dig up a dozen incidents where radioactive materials were accidentally mishandled and/or released at national labs such as Los Alamos. And people working there likely have far more training and knowledge than Average Joes working at a smoke detector factory.
When microscopic amounts of these materials can be extremely dangerous and highly carcinogenic, I simply can't understand why we're even messing around with this stuff.
But, I assume, none for smoke detectors.
We've told you, but you won't listen. The things you are saying are quite simply meaningless. The first part of that sentence in particular. It sounds scary but means absolutely nothing.
The amount and means of exposure matters. This is true for anything that is potentially harmful. From sunlight to water.
The radon in your basement will similarly kill you. If it decides to decay at an inopportune moment you will be similarly at risk. Without the numbers no decision can be rationally made. Inthe big scheme smoke detectors are a problem, but a very small one. Let us worry about the big ones.
This is called science.
Cyanide is dangerous.
Cyanide is a 3 syllable word beginning with C.
Therefore we need to avoid all three syllable words beginning with C.
Therefore prudent avoidance indicates that we shouldn't eat celery.
Simple logic.
  • Haha
