Solar radiation intercepted by Mars surface
18 replies · 5K views
helpemz2011
Earth and Mars are both rocky planets, but Mars is half as far away again from the Sun as Earth, so radiation from the Sun is not as powerful at the surface of Mars as at the Earth’s surface.
Using the values in Table 2, calculate the amount of solar radiation intercepted by the surface of Mars. Give your answer in scientific notation, to the appropriate number of significant figures, and in the correct units.
Table 2 Values of solar constant (W m−2) and area facing the Sun (m2) for Mars.
Mars
Solar constant (W m−2)
5.20 × 102
Area facing the Sun (m2)
3.6 × 1013
5.20x10(p-o)2 / 3.6x10(p-o)13 = 1.444444444x10(p-o)15 -
1.4x10(p-o)15 W m
Can anyone tell me what i am doing wrong if my answer is wrong (which i am sure it is)
Cheers emz
Your result should be in watts (total amount of solar radiation incident on the surface of Mars). Look at the units of what you're given, and see what relationship will produce the desired resulting units.
To be honest i really don't know sorry i am really stuck. Are my calculations on the right track?
emz
No. You've got problems with the units. You need to understand how units combine when you do the math. They will guide you to the correct way to solve problems like this.
You are given the solar constant at Mars in W/m2, and the surface area catching the radiation in m2. You want a result in watts. How do you combine the given information?
Divide the area facing the sun by the solar constant?
Are you sure about this statement?
helpemz2011 said:
Joules?
Watts. You want watts. That's energy per unit time (Joules per second).
Let's see how those units work out:
[tex]\frac{[m^2]}{[W/m^2]} = \;??[/tex]
What does that yield?
Yeah that's what is in the question.
and W?
I just don't know I might just give up on this question sorry
Emz
I'm going to bridge dimensional analysis with our good old friend apples.
You have baskets which hold 30 apples each. The units are apples/basket.
You have 12 baskets, how many apples do you have?
Now you have 30 Watts/metre². How many Watts are incident on a sphere with a radius of 100 metres? Its the same process.
You seem to be flustered because you are overestimating the problem and underestimating your abilities. Also, Mars is not half the distance from the sun than the Earth.
dacruick said:
"Earth and Mars are both rocky planets, but Mars is half as far away again from the Sun as Earth, so radiation from the Sun is not as powerful at the surface of Mars as at the Earth’s surface."​
Earth is at 1AU, Mars at about 1.5AU (okay, 1.523AU to be picky). So sure, the statement's okay.
ha solar constant x area facing the sun!
so 5.20x10(p-o)2 x 3.6x10(p-o)13 = 1.872x10(p-o)16
to appropriate significant figures -1.9x10(p-o)16 W
Bravo!
By the way, you can use the x2 and x2 buttons on the edit page to produce "real" superscripts and subscripts.
cheers its a pain in the backside writing (p-o) all the time thank you both x
helpmz2011
You may not post any of the TMA questions from The Open University on a public forum. This is considered to be cheating.
helpemz2011
If you read the textbook for S104 that you got you will find the method to do all the calculations you have asked about.
It is against the rules to post TMA questions to public forums and I suggest you di8scuss this within your tutor group forum in future.
EW
