Solids of revolution question
  • Thread starter Thread starter lionely
    Revolution Solids
26 replies · 3K views
lionely
Find the volumes of the solids generated
a) x-3y+3= 0, x=0 , y=2 about the x axis
I sketched the graph got a straight line,
I then proceeded to integrate y2
∏∫y2δx
=[(x^3/27)+(x^2/3)+ (x)] from x=3 to x=-3
I got 8∏
but the answer is 5∏
b) x-y2-1=0, x=2 about the y-axis
∏∫x2δy
= [ (y^5/5) + (2y3/3) + (y)] from x=1 to x=-1
I got (56/15)∏ for this one but the answer is (64/15)∏
a) First off, don't memorize these formulas, you have to understand what's going on.
You're asked to find the area between:
y=(x+3)/3, x=0, y=2 about the x-axis
So the graph looks like this:
Now, the way to do this problem is that you need to subtract the outer radius from the inner right?
So what does the integral become?
Uh is it the intergral of (x/3) +1 - (integral of y=2)?
First, it is clear from the graph that the line y= 2 is above the line y= x/3+ 1. Your calculation will give a negative volume!
Second, you want to subtract the volumes, not just the integrals! The volume given by y(x) rotated around the x-axis is [itex]\pi\int y^2 dx[/itex].
Adding onto what HallsofIvy said, what you're doing is subtracting the volumes of the two rotations, so technically you can have 2 integrals but they would be:
[tex]\pi\int (outer)^{2}dx-\pi\int (inner)^{2}dx[/tex]
This is just using pi r^2 to find the area of a piece of the circle, the dx would be the width of the circle and the integral because it is the sum of many pieces between 2 points.
Do you see why that works?
∏∫(4)^2dx− ∏∫(((x/3)+1)^2dx ?
Oh when I do this from x=0 to x=3 I do get 5∏
I got the 2nd one too. Thanks everyone
That's correct.
Oh may I ask one more question? I think I got the answer but not sure if my method was correct.
Which problem are you asking about? If it's the first problem, you can do this in a couple of ways: by "washers" (disks with holes in them) or by cylindrical shells (sort of like the layers in an onion).
Either way should produce the correct answer, but often one way will be easier than the other, so it pays to be comfortable using both ways. Also, the advice given by iRaid to not memorize the integration formulas is good advice. However, you do need to know the formulas for the area of a circle and for the area of a rectangle, both of which are pretty simple.
To get the volume of a disk, it's just the area of the circle times the thickness of the disk, which will usually be either Δx or Δy.
To get the volume of a washer, find the volume of the outer disk, and subtract the volume of the inner disk (the hole).
To get the volume of a shell, you need the area of a rectangle times its thickness. One of the dimensions of the rectangle comes from the circumference of the cylindrical shell, which would be ##2\pi## times the radius of the shell. The length is just the length of the shell, and the thickness is either Δx or Δy.
It is extremely important to draw a picture of the region that will be rotated, and as good a sketch of the solid of revolution as you can manage. If you don't draw these pictures, there's a very good chance that the integral you set up will not produce the correct answer.
Well the question was to find the volume generated by
y=1/x , y=1 , x=2 about y=0
I did this
∏∫(1/x^2).dx from x=0 to x=2 I got -1/2∏
then ∏∫1.dx =[x] from x=0 to x=2 and I got ∏
then I did this ∏-(1/2)∏ = 1/2∏
is this correct?
Do you mean between x = 1 and x = 2?
Also, is the region between the graph of y = 1/x and the x-axis?
Try to be more precise in what you ask.
lionely said:
I did this
is this correct?
Find the volumes of the solids generated when each of the areas enclosed by the following curves and lines is rotated about y=0
y=1/x , y=1 , x=2
Uhh I tried I sketched y=1/x and drew in the line y=1
and the region is somewhere between y=1/x and y=1 right?
Right, and the region is also bounded by the line x = 2. So where does the curve intersect the line y = 1?
The curve meets y=1 at x=1
Oh... so that's how I should get 1/2pi thanks
lionely, you have to understand the concept of this. Believe me, if you just learn the formulas and not HOW this stuff works, you'll fail during the exam. The next thing you're going to be learning is the shell method which builds upon this even more. When your teacher starts throwing in rotations around lines that aren't the x and y axis, you'll be completely screwed.
But I thought I should integrate 1/x^2
then evaluate [-1/x] from x= 1 to x =2?
That's not the whole integrand.
These are the right integration limits, but it looks like you don't have the right integrand.
I don't think you have a drawing (or maybe a good drawing) of the region that's being rotated. The region being rotated is the roughly triangular region above the curve y = 1/x, below the line y = 1, and to the left of the line x = 2.
Each area element is a vertical strip of width Δx. Each area element, when rotated, is in the shape of a washer whose volume is the area of the washer times its width, Δx.
OKAY SIR I THINK I got it if not I truly hate integration , xD.
I got 1/2pi from evaluating [-1/x]
NOW I now find the volume under y=1 for the same interval
I get pi NOW
I then subtract the volumes ( Pi - 1/2pi) = 1/2pi cu. units.
Edit: I made a mistake in evaluating the antiderivative.
[STRIKE]No, that's the same as you got earlier, and it's still not right.
[/STRIKE]
What does your integral look like?
$$ \pi \int_1^2 (f(x)) dx$$
If you "Quote" my post, you can use my LaTeX above and fill in the integrand.
Mark44 said:
[STRIKE]No, that's the same as you got earlier, and it's still not right.[/STRIKE]
$$ \pi \int_1^2 (1-(1/x^2)) dx$$
the 1 is from y=1
and the other is y=1/x
also the answer in my textbook is (1/2)∏
Perfect. The answer is as you show, ##\pi/2##.
I subbed in a wrong value in my work. I'm sorry if I caused you any grief...
