How Much Epsom Salt for a 15% Magnesium Sulfate Solution?
  • Thread starter Thread starter HarryA
    Magnesium
This discussion focuses on calculating the amount of Epsom salt (magnesium sulfate heptahydrate, MgSO4·7H2O) required to create a 15% magnesium sulfate solution by mass in water. The calculations reveal that to achieve 1.24 pounds of magnesium sulfate, approximately 2.54 pounds of Epsom salt is necessary. The atomic weights used in the calculations are Mg=24.3, S=32.06, and O=16, leading to a total molecular weight of MgSO4 as 120.36 and MgSO4·7H2O as 246.36. The discussion emphasizes the importance of accounting for the water content in Epsom salts when determining the required mass.
  • Understanding of molecular weights and atomic mass calculations
  • Basic knowledge of solution concentration and mass percentage
  • Familiarity with Epsom salts and its chemical composition
  • Ability to perform unit conversions (pounds to gallons)
  • Research the properties and uses of magnesium sulfate in various applications
  • Learn about solution preparation techniques and concentration calculations
  • Explore the implications of hydration in chemical compounds
  • Investigate the safety and handling procedures for Epsom salts in practical applications
Chemistry students, laboratory technicians, and hobbyists involved in solution preparation or chemical experiments will benefit from this discussion.
HarryA
I would like to make a solution of magnesium sulfate (MgSO4) that is 15%
magnesium sulfate by mass in water. As magnesium sulfate is sold as epsom salts which is
MgSO4 7H2O I need a way to calculated the epsom salts required for the required
magnesium sulfate or 1.24 pounds per gallon of water (Water at 8.35 pounds per gallon).I am thinking one goes by atomic weight?
For MgSO4:
Mg= 24.3 S= 32.06 Oxgen4= 4* 16 = 64 MgSO4= 120.36
For 7H2O:
7H2 = 7*1*2 = 14 7Oxgen = 7* 16 = 112 7H2O= 126.0
For MgSO4 7H2O= 120.36 + 126.0 = 246.36
So to get 1.24 pounds of MgSO4: 1.24 * 246.36/120.36 = 2.05 pounds perhaps?
Thanks in advance.
Chemistry news on Phys.org
HarryA said:
MgSO4= 120.36
Check.
HarryA said:
7H2O= 126.0
Check.
Check.
Not check.
Take another swing at the proportion. You'll also want to account for the mass of water you're adding as hydrate.
Thanks.
So the ratio of water in epsom salts is: 126.0/246.36 = 51.14 % by weight and
48.86% MgSO4. So 48.86% of what weight of epsom salts is 1.24 pounds of MgSO4?
Epsom salts = 1.24/0.4886 = 2.54 pounds ?
I need to fill my RC blimp envelope with hydrogen.
  • · Replies 21 ·
  • · Replies 32 ·
