Solution of Poisson's Equation
The solution to Poisson's equation in electrostatics is derived using Green's function, particularly in three dimensions. The equation is expressed as $$\nabla^2\phi=-\frac{\rho}{\epsilon_0}$$, where the potential $$\phi$$ for a point charge is given by the Coulomb potential $$\phi_{\text{C},\vec{x}'}(\vec{x})=\frac{q}{4 \pi \epsilon_0|\vec{x}-\vec{x}'|}$$. The Green's function for the operator $$-\Delta$$ is established as $$G(r)=\frac{1}{4 \pi r}$$, which is essential for solving Poisson's equation for continuous charge distributions. The derivation involves integrating over the charge density and applying Gauss's Law.
  • Understanding of Poisson's equation and its physical significance
  • Familiarity with Green's functions in mathematical physics
  • Knowledge of electrostatics and Coulomb's law
  • Basic proficiency in calculus, particularly integration techniques
  • Study the derivation of Green's functions for different boundary conditions
  • Explore applications of Poisson's equation in electrostatics and potential theory
  • Learn about the Laplace operator in spherical coordinates
  • Investigate the physical implications of charge distributions and their potentials
Physicists, electrical engineers, and students studying electrostatics or mathematical physics will benefit from this discussion, particularly those interested in the mathematical foundations of potential theory and Green's functions.
DirecSa
We all know that Poissson's equation in electrostatic is:
My question is: why the solution, let's say for 1D, is not just double integral as follows:
$$\phi=\iint -\frac{\rho}{\epsilon_0} d^2x$$
which gives x square relation. But the actual solution comes from using Green's function and it gives the relation one over r (1/r). I need the connection between these things how they come to this and not that...
Thank you!
It should be
$$\Delta \phi=-\frac{1}{\epsilon_0} \rho.$$
In 1 dimension the equation simply reads
$$\phi''=-\frac{1}{\epsilon_0} \rho,$$
and this you get a solution by simply integrating twice wrt. ##x##.
However in more than 1 dimension you need the Green's function, and it's easy to find from physical arguments in this case: For the point charge ##q## at position ##\vec{x}'## the potential is of course the Coulomb potential
$$\phi_{\text{C},\vec{x}'}(\vec{x})=\frac{q}{4 \pi \epsilon_0|\vec{x}-\vec{x}'|}.$$
Now you can consider the continuous charge distribution, described by the charge density ρ, as consisting of an infinite number of infinitesimal charges ##\mathrm{d} q=\mathrm{d}^3 x' \rho(\vec{x}')##, located around ##\vec{x}'##, and because the Poisson equation is linear you get the total potential by summing or, since we have a continuous charge distribution, rather integrating, over the Coulomb potentials of all these charges, i.e.,
$$\phi(\vec{x})=\int_{\mathbb{R}^3} \mathrm{d}^3 x' \rho(\vec{x}') \frac{1}{4 \pi \epsilon_0 |\vec{x}-\vec{x}'|}.$$
Formally the charge density of a point charge is
$$\rho_{\text{P},\vec{x}'}(\vec{x})=q \delta^{(3)}(\vec{x}-\vec{x}').$$
and that's why the Coulomb potential is the Greens' function of the operator ##-\Delta## in the sense that from this it follows that
$$-\Delta \phi_{\text{C},\vec{x}'}(\vec{x}')=-\Delta \frac{q}{4 \pi \epsilon_0 |\vec{x}-\vec{x}'|} = \frac{q}{\epsilon_0} \delta^{(3)}(\vec{x}-\vec{x}').$$
These hand-waving physical arguments can of course be made mathematically rigorous.
Thank you so much, now it is more clear for me. And also I added the minus. Maybe just a question regarding the 4pi in the denominator.. does it come from a physical definition or mathematical concept?
That comes from finding the Green's function. The idea is not so difficult. You need to solve for
$$-\Delta G(\vec{x})=\delta^{(3)}(\vec{x}).$$
The right-hand side is obviously rotation symmetric. That's why we can conclude that ##G## should depend on ##r=|\vec{x}|## only. Now using the Laplace operator in sphercical coordinates, this leads to
$$-\frac{1}{r} [r G(r)]''=0 \quad \text{for} \quad r \neq 0.$$
You get the general solution by just integrating twice (it's effectively a 1D problem due to this symmetry!):
$$(r G)''=0 \; \Rightarrow r G=A+B r \; \Rightarrow \; G=\frac{A}{r} + B$$
with integration constants ##A## and ##B##. First we want to have ##G \rightarrow 0## for ##r \rightarrow \infty##. This implies ##B=0##. Thus you have
$$G(r)=\frac{A}{r}.$$
To get ##A## we integrate ##\Delta G(r)## over a sphere of radius ##a## around the origin and use Gauss's Law,
$$\int_{S_a} \mathrm{d}^3 r \Delta G(r) = \int_{\partial S_a} \mathrm{d}^2 \vec{f} \cdot \vec{\nabla} G(r).$$
The surface normal vector in spherical coordinates is
$$\mathrm{d}^2 \vec{f} = a^2 \sin \vartheta \mathrm{d} \vartheta \mathrm{d} \varphi \vec{e}_r.$$
The gradient is
$$\vec{\nabla} G(r)=G'(r) \vec{\nabla} r = G'(r) \vec{e}_r=-\frac{A}{r^2} \vec{e}_r$$
and thus
$$\int_{S_a} \mathrm{d}^3 r \Delta G(r) = -\int_0^{\pi} \mathrm{d} \vartheta \int_0^{2 \pi} \mathrm{d} \varphi a^2 \sin \vartheta \frac{A}{a^2} = -4 \pi A.$$
On the other hand ##\Delta G(r)=-\delta^{(3)}(\vec{r})## and thus
$$\int_{S_a} \mathrm{d}^3 \Delta G(r)=-1 \; \Rightarrow \; -4 \pi A=-1 \; \Rightarrow \; A=\frac{1}{4 \pi}.$$
Thus the Green's function of ##-\Delta## is
$$G(r)=\frac{1}{4 \pi r},$$
which is what we wanted to prove.
very grateful, thank you a lot :)
  • · Replies 29 ·
