High School Why Must the Expression Inside a Square Root Be Non-Negative?
The expression inside a square root must be non-negative when dealing with real numbers because the square root of a negative number is not defined in the real number system. For the equation √(5x - 4) to yield a real solution, the condition 5x - 4 ≥ 0 must be satisfied, which simplifies to x ≥ 4/5. This restriction ensures that the square root produces a valid real number. If the expression is negative, it leads to complex numbers, which are not acceptable in contexts requiring real solutions. Therefore, it is crucial to state this restriction explicitly when solving equations involving square roots.
mech-eng
When we find solution set of an equation inside a square root why we should assume that inside of square root should be equal to or greater than zero? For example ##\sqrt{5x-4}##.
How can I use here equal to or greater than zero symbol?
Thank you.
Mathematics news on Phys.org
As long as you are restricting yourself to real numbers, the expression under the square root sign has to be non-negative, so you can square if you want, but then you need to add & ##5x -4 \ge 0##
Likes mech-eng
For only real number, I cannot see that reason which restricting inside a square root being ##\ge 0##? I think it is not easy to see this. Yes if I take the square of both sides it is ##5x-4\ge 0##. This is an easy step but can it give any explanation?
Thank you.
mech-eng said:
reason which restricting inside a square root being ≥0
There is no real number ##x## for which ##x^2 < 0 ##
Likes mech-eng
But there can be ## real\ numbers ## which can make ##5x-4## negative so when putting ##5x-4## inside a square root why should these values be neglected? I cannot understand this part easily.
Thank you.
Because sometimes a complex solution is not acceptable. If you have ##t = \sqrt{5x-4}##, where ##t## is time, then only real solutions are physically acceptable.
Without thinking both complex numbers and meaningful physical situation, i.e from respect of pure real numbers, what is the reason?
Thank you.
If you restrict the codomain of a function to the real numbers, then that may restrict its domain.
Because for ##\sqrt{5x - 4}## to be real, ##5x - 4## must be greater than or equal to 0. Otherwise (if ##5x - 4 < 0##), you'll be taking the square root of a negative number.
Yes this explains it but requires more thinking. Would you please check if this explanation expanding it correct?
"If ##5x-4## negative real number and if we put it into square root ##\sqrt{5x-4}## cannot a real number because when we take square of ##\sqrt{5x-4}^2## this will be ##5x-4##, a negative real number, which is imposibble.
Thank you.
You should not assume that 5x-4 is ≥0. You should state that your answers are only valid for 5x-4 ≥0. That is significantly different.
You can allow square roots of negative numbers if you are willing to talk about imaginary and complex numbers.
PS. When you are editing a post, the ≥ symbol (and many others) is available by clicking the Σ symbol at the top right.
But I regard only reel numbers, do not assume complex numbers.
Thank you.
Thank you.
I understand. Just a little "word-smithing". I don't like using the word "assume" when that may not be true. It's better to state a restriction that is required to make something valid than to assume it.
Like: ##\sqrt{5x-4} = etc... ; x ≥ 4/5 ##
Then you should also keep track of those restrictions when you give your final answer.
But does not #10 explains corrrectly why this restriction should be?
Thank you.
Thank you.
Yes, it does. As long as you keep in mind that it is a restriction that you should keep track of, rather than an assumption that you don't need to worry about.
Likes mech-eng
Added to post #11 probably after you read it:
You're making it much more complicated that it needs to be.
From post #1,
The usual square root function, the one that produces a real number, is defined only for expressions whose values are ≥ 0. This means that ##5x - 4 \ge 0## must be true, or equivalently, ##x \ge \frac 4 5##. In this case, if 5x - 4 < 0, its square root will not be a real number.​
That's all you really need to say.
  • · Replies 45 ·
  • · Replies 16 ·
  • · Replies 22 ·
