Solve Algebra 2 Problems 3, 7, 9 & 19
  • Thread starter Thread starter mustang
    Algebra Algebra 2
3 replies · 2K views
mustang
Problem 3. The sum of the two numbers is 3 and the sum of their reciprocas is 12/5. Find the numbers.
Problem 7. What is the linear term of the equation
q = 3x^2 + 2x - 1?
Problem 9. Write the equation of the ellipse with foci at (12,1) and (-12,1) and the endpoints of the major axis at (0,6) and (0,-4) Then graph the ellipse.
Problem 19. If f(x)=3x^2-2 and g(x)=2x^2+3, find[f o g](-4)
Problem 3.
Let your two unknown numbers be m and n. You're given two statements about the relationship between m and n. Each statement can be written as an equation. You'll have two equations and two unknowns. You can solve this system of equations simultaneously for m and n.
The first equation is absolutely trivial. Hint on the second: The reciprocal of m is 1/m .
Show us a little of what you've done so we can help a little more.
2 equations, 2 variables, 2 easy :biggrin:
[tex]x + y = 3[/tex]
Isolate one of the variables.
[tex]x = 3 - y[/tex]
Now write the other equation
[tex]\frac{1}{x} + \frac{1}{y} = \frac{12}{5}[/tex]
Substitute the isolated variable.
[tex]\frac{1}{3 - y} + \frac{1}{y} = \frac{12}{5}[/tex]
Now multiply each term by all of the denominators.
[tex]5y + (15 - 5y) = 36y - 12y^2[/tex]
Just solve for that equation and you'll have Y. Then substitute that answer for Y back into the first equation.
I think you are supposed to fill in -4 for the g equation, then use the g equation as x in the f equation. It's like this:
f(g(-4)) = ??
