Solve bernoulli differential equation with extra constant
The discussion focuses on solving the Bernoulli differential equation given by u'(t)=c*u(t)^2-c*(a+b)*u(t)+c*a*b. The initial solution for the homogeneous part is identified as u_0(t)=(1/(a+b)+d*e^{c(a+b)t})^{-1}. Participants clarify that the equation can be expressed in a linear form, allowing for the use of linear operators. The consensus suggests that separation of variables is a more effective method than attempting to combine solutions of the homogeneous and non-homogeneous parts.
  • Understanding of Bernoulli differential equations
  • Familiarity with linear operators in differential equations
  • Knowledge of separation of variables technique
  • Basic skills in manipulating exponential functions
  • Study the method of separation of variables in differential equations
  • Learn about linear operators and their applications in solving differential equations
  • Explore advanced techniques for solving Bernoulli differential equations
  • Practice solving non-linear differential equations using various methods
Students studying differential equations, mathematicians, and educators looking to deepen their understanding of Bernoulli equations and solution techniques.
Berrius
Find a solution for:
I've found the solution for the homogeneous equation:
u_0(t)=(\frac{1}{a+b}+d*e^{c(a+b)t)})^{-1}
Where c is a random constant.
Now I've tried the solution u(t)=x(t)*u_0(t), when I fill this in it gets a mess and i can't figure out what x(t) should be.
Can someone help me?
This isn't a linear equation, so I'm not sure what you consider the "homogeneous" equation. If you write it as$$
u'+ c(a+b)u =cu^2+cab$$at least the left side of the equation is linear. That means if you can find a solution ##u_1## of ##u'+ c(a+b)u =cu^2## and a solution ##u_2## of ##u'+ c(a+b)u =cab## then ##u_1+u_2## should be a solution of your original DE.
With homogeneous I just ment the differential equation without the constant part.
But your approach won't work because u'(t)=u_1'(t)+u_2'(t)=-c(a+b)u_1(t)+cu_1^2(t)-c(a+b)u_2(t)+cab=-c(a+b)u(t)+cu_1^2(t)+cab
Or am I seeing it wrong?
I would forget Bernoulli's equation and just try separation of variables. The right side factors. Just use partial fractions to integrate it.
Right. You can't combine them that way. Just separate.
You are seeing it wrong. If you let$$
L(u) = u' + c(a+b)u$$be the left side linear part then ##L## is a linear operator, which means ##L(u_1+u_2) = L(u_1)+L(u_2)##. So if ##L(u_1) = cu_1^2## and ##L(u_2)=abc##, what do you get for ##L(u_1+u_2)## ?
But you want to get ##L(u_1+u_2) = c(u_1+u_2)^2+abc##. You don't get that.
No wonder I was feeling a little uncertainty about my argument. :blushing: And it seemed so neat at the time...
