Solve Change in Voltage: Why is V=ED?
  • Thread starter Thread starter collegeconfid
    Change Voltage
collegeconfid
Why is the change in voltage between two capacitors V=ED ?
V=-ED
Isn't the change in voltage equal to the negative of the product of the electric field and displacement?
So, why is it that for a capacitor the change in voltage is not V=-ED ?
Thanks for any help.
The flow of electrons through a capacitor is directly proportional to the rate of change of voltage across the capacitor, but in the case of resistors it is directly proportional to the voltage drop.. from there it appears the difference.. at least that's what I think :)
There is some confusion when speaking about voltage. Some people call the electric potential "voltage" others define voltage as potential drop. According to Ohm's law, the current I causes a potential drop - voltage- across a resistor R, equal to V= IR, but the electic potential changes by -IR in the direction of the current.
Between the capacitor plates, the potential U changes by -ED in the direction of the electric field, that is from the + plate to the - one, and by + ED in the opposite direction. Or you can say that the potential of the positive plate is by ED volts higher than the potential of the negative plate.
ehild
