Solve Coilgun Inefficiency & Measure Projectile Speed France
The discussion revolves around the inefficiencies encountered in a coilgun project, specifically addressing issues related to projectile acceleration and speed measurement methods. Participants explore various technical aspects of coilgun operation and measurement techniques, including potential improvements and safety considerations.
  • One participant notes that the projectile stops midway, raising questions about the timing of coil switching and potential inefficiencies in the setup.
  • Another suggests using a chronograph for speed measurement, sharing that it is commonly used in firearm applications.
  • A different approach involves analyzing the sound of the projectile's friction within the solenoid, though the participant struggles to correlate sound intensity with projectile speed.
  • One participant emphasizes the importance of switching coils at the right moment to maximize efficiency and discusses the potential for energy reclamation from the magnetic field.
  • There are suggestions to increase voltage for better efficiency and to use larger mass projectiles or materials with high magnetic permeability to enhance performance.
  • A participant shares personal experiences with different capacitor setups and their impact on muzzle energy and projectile speed.
  • Concerns are raised about the safety of working with high energies, particularly regarding the OP's experience level.
Participants express various methods and ideas for improving coilgun performance and measuring speed, but there is no consensus on the best approach or resolution of the inefficiencies discussed. Safety concerns regarding high-energy setups are acknowledged, leading to a decision to close the thread.
Participants mention the importance of timing in coil switching and the challenges of measuring speed accurately, indicating that assumptions about the setup and measurement methods may not be fully resolved.
oum
Hi,
I've built a coilgun using a solenoid, but my projectile stops at the half of the road, but this way i can't measure neither the acceleration nor the speed. what could be wrong ? how to push it further ?
I also have a question about the efficient methods to measure the speed of the projectile. I've thought about the accoustic method, but it was not efficient since the room where i do the experiences is not isolated.
btw i study in France so excuse me if i don't use a proper vocabulary.
oum said:
Hi,
Welcome to the PF, and your English vocabulary and grammar are fine. :smile:
Can you UPLOAD a schematic of your setup, and a couple pictures? That will help us to help you out.
A coil gun involves switching at just the right instants in time to continue to accelerate the projectile. It sounds like you may not be switching, or at least not switching at the right moments.
A chronograph is a great method to measure the speed of a projectile. You can purchase a chronograph, or borrow one from a firearm enthusiast.
A lot of rifle cartridge reloaders (like myself) use chronographs to measure the velocity of the rifle's projectile. They experiment with different quantities and types of gunpowder, primers, and projectiles to suit their needs and monitor their batches of cartridges for consistent performance (low std dev).
actually, I've tested lately a new method which is to record the sound of the friction of the projectile in the solenoid and analyse it with audacity, but i still can't find the link between sound intensity and the Instantaneous speed of the projectile.
As for making your coilgun more efficient, there's a few things you could do.
First, like Dr.D said, you need to switch your coils at just the right time. For my own coilguns, I've always used a setup like this:
The idea is that the projectile itself acts as a switch for the coil. Once it travels between one third and half of the length of the coil, the contact breaks and the magnetic field collapses. If you're smart about your circuit, you can actually re-claim the energy left in the magnetic field for the next shot, or additional stages.
Keep in mind that the magnetic field will take some time to collapse, and also that the force on the projectile becomes very small towards the center of the coil. There isn't much benefit to making the projectile go all the way to the halfway point before switching the coil off - in fact, doing so may actually slow it down again because the magnetic field doesn't collapse instantly.
Secondly, use higher voltages. Higher voltages are generally more efficient, because you can use coils with more turns - and thus get the same magnetic field strength with less waste heat. Even if you use the same coils, the higher voltage causes a much sharper increase in current, so you're building up your magnetic field much more quickly. Just keep in mind that this also means that your coils store more energy, and so it becomes important to either use it all in one go, or to add some circuitry to re-claim that energy for a 2nd or even a 3rd stage.
Re-claiming energy is "dangerous" too, though, because the projectile will always keep a residual magnetic field, and you can actually slow it down by doing this.
Third, use a large mass! Coilguns are inherently slow because the inductance of the coils limits how quickly you can build up and destroy a magnetic field, and a large mass can pull energy out of a coil's magnetic field much more quickly than a small mass. Also use materials with a high magnetic permeability, because a stronger attraction means faster conversion from magnetic potential to kinetic energy.
You could also use magnets as projectiles. I did this and it really helps with relatively low-energy coilguns.
I've driven my early coilguns using a single 400V/2200uF capacitor and managed to get muzzle energies of 20-30 Joules at roughly 35 m/s with that. For later experiments, I used an 800V/1200uF capacitor bank, and I got muzzle energies in excess of 50J with that, at around 60 m/s and a lighter projectile.
I always measured the velocity by shooting across a given distance, recording the shot on camera, and then timing how long it took the projectile from the moment it was fired until its impact on the target. Not the most accurate, but good enough for relatively low velocities if you have limited equipment.
@SirLollington -- You are working with fairly high energies there, and I'm not sure that the OP @oum has the background and experience to work with such energies safely. It sounds like you do have the appropriate background to work relatively safely with those voltages and currents, but we are going to close this thread now because it is approaching the "dangerous activity" stage, which we do not allow on the PF for safety and liability reasons.
Thank you to all who have participated.
  • · Replies 26 ·
11K
17K
