Solve Euler-Cauchy Problem: x^2y" - 2xy' +2y = x^4e^x
  • Thread starter Thread starter ryan8888
The forum discussion focuses on solving the Euler-Cauchy differential equation: x²y'' - 2xy' + 2y = x⁴e^x. The user successfully derives the characteristic equation and finds the complementary solution, yc = c₁x + c₂x², using the roots m₁ = 1 and m₂ = 2. The discussion emphasizes the application of the variation of parameters method and the Wronskian, which is determined to be w = x². The user seeks clarification on the derivation of the particular solution and the role of the Wronskian in this context.
  • Understanding of Euler-Cauchy equations
  • Familiarity with the method of variation of parameters
  • Knowledge of Wronskian determinants
  • Basic calculus, including differentiation and integration
  • Study the method of variation of parameters in detail
  • Learn how to compute the Wronskian for different functions
  • Explore examples of solving non-homogeneous differential equations
  • Review the properties and applications of Euler-Cauchy equations
Students and educators in mathematics, particularly those focusing on differential equations, as well as anyone seeking to deepen their understanding of the Euler-Cauchy equation and its solutions.
ryan8888
Find the General Solution of x^2y" - 2xy' +2y = x^4e^x
I just recently began learning about the Euler-Cauchy Equation and have been able to follow it until I hit the part for the Complementary Equation. I'm having a little truoble understanding how to set up the Wronskian.
Here is what I came up with for this problem:
My auxilliary equation is M2 + (a-1)m + b =0 with a = -2 and b= 2
So I have: m2 - 3m +2 =0
Solving for the Roots: (m-1)(m+2) = 0
m1 = 1 and m2 =2
Because these are real and distinct roots my characteristic equation is yc = c1x + c2x2
This is where I get stuck. I have to solve for the Particular solution and the example I found uses a Wronskian to do so. I'm familiar with the method in which I would make a guess at the general solution, take the derivatives and then substitute them into the original ode and solve for the constants.
Here I know the Wronskian is w(x,x2) But I'm not entirely sure where the x and x2 are obtained from. Are they simply the 2 x components of the ODE and secondly if they are does the order in which they are listed have any bearing on the outcome of the solution?
You are talking about the "variation of coefficients" method which can be written as a single formula involving the Wronskian. Here are the more fundamental ideas behind that formula.
We know that solutions to the associated homogeneous equation are x and x^2 so we look for a solution of the form y= xu(x)+ x^2v(x) for some functions u and v. y'= u+ xu'+ 2xv+ x^2v'. Now, there are an infinite number of solutions of that form so we can simplify our search by adding the requirement that xu'+ x^2v'= 0 so that y'= u +2xv. Differentiating again, y''= u'+ 2v+ 2xv'.
Now, put those into the differential equation:
x^2y''- 2xy'+ 2y= x^2u'+ 2x^2v+ 4x^3v'- 2x^2u'- 2x^3v'+ 2xu+ 2x^2v
= 2x^3v'= x^4 e^x
v&#039;= \frac{1}{2}xe^{x}[/itex]<br /> (It is that &quot;2x^3&quot; that was the Wronskian.)<br /> You can integrate that to find v. And then the previous xu&amp;#039;+ x^2v&amp;#039;= xu&amp;#039;+ \frac{1}{2}x^3e^x= 0 reduces to u&amp;#039;= -\frac{1}{2}x^2e^x.<br /> <br /> <br /> You don&#039;t normally get a single equation in one variable as happened here. What typically happens is that you get an equation in both u&#039; and v&#039; (There is no u&#039;&#039; or v&#039;&#039; because of or requirement that xu&amp;#039;+ x^2v&amp;#039;= 0. There is no u or v because x and x^2 satisfied the homogeneous equation.) which, together with our &quot;requirement&quot;, gives two equations to solve for u&#039; and v&#039;.<br /> <br /> You may know that if you solve a pair of equations, like ax+ by= p, cx+ dy= q, the solutions will involve the determinant<br /> \left|\begin{array}{cc}a &amp;amp; b \\ c &amp;amp; d\end{array}\right|<br /> in the denominator.<br /> <br /> That is the Wronskian here.
Okay I see what you hac done there.
I was browsing around the internet because I'm not familiar with variation of parameters and found the following:
w = \left|\begin{array}{cc}y1a &amp; y2 \\ y&#039;1 &amp; y&#039;2\end{array}\right| which I solved to get x^2
The next step was to solve for w1 and w2:
w1 = \left|\begin{array}{cc}0 &amp; y2 \\ f(x) &amp; x^2\end{array}\right| which is:
w1 = \left|\begin{array}{cc}0 &amp; x^2 \\ x^2e^x &amp; 2x \end{array}\right| according to my example. Why is the f(x) = x^2e^x when the f(x) in the problem is x^4e^x?
I feel like I am missing a step in here.
Thanks for your continued help
We know that solutions to the associated homogeneous equation are x and x^2 so we look for a solution of the form y= xu(x)+ x^2v(x) for some functions u and v. y&#039;= u+ xu&#039;+ 2xv+ x^2v&#039;. Now, there are an infinite number of solutions of that form so we can simplify our search by adding the requirement that xu&#039;+ x^2v&#039;= 0 so that y&#039;= u +2xv. Differentiating again, y&#039;&#039;= u&#039;+ 2v+ 2xv&#039;.
x^2y&#039;&#039;- 2xy&#039;+ 2y= x^2u&#039;+ 2x^2v+ 4x^3v&#039;- 2x^2u&#039;- 2x^3v&#039;+ 2xu+ 2x^2v
= 2x^3v&#039;= x^4 e^x
  • · Replies 18 ·
