tydychic
- 24
- 0
A 2.0kg (M) block hangs from the bottom of a 1kg (m), 1m (L) rod. The block and rod form a pendulum that swings on a frictionless pivot at the top end of the rod. A .01kg bullet (m') is fired into the block, where it sticks, causing the pendulum to swing out to a 30 degree angle. What was the speed of the bullet (v)? You can treat the wood block as a particle.
Using conservation of energy: .5m'v^{2}=(M+m+m')gh, with h=L-Lcos(30degrees)
v=Square root[2(.01kg + 1kg + 2kg)(9.8m/sec^{2})(1m-cos(30degrees))/.01kg)]=28.11m/s
However, the given answer is 3.9 x10^{2}m/s...
I've been working on this problem for north of six hours now. I will greatly appreciate any insight anyone can give me.
