Solve Imperial to Metric Conversion Error for Roll Bar Rate
  • Thread starter Jas1159
    Rate Roll
2 replies · 5K views · last reply
Jas1159
I have an equation taken from a book that when converting from imperial to metric gives me the complete wrong answer when converting back afterwards... it seems simple but I am obviously missing a trick, can anybody help?
Imperial Equation
Angular Rate / (Lever Length2 x pi /180) = Roll Bar Rate (in*lbs)
75.46in*lb / (7in^2 * pi / 180) = 88.24 (in*lbs)
Metric Equation
0.892m*kg / (0.178m^2 * pi / 180) = 1618.035 (m*kg)
Converting 1618.035m*kg to in*lbs gives 140439.1994in*lbs
Jas1159: lbf should be converted to Newton (N), not kg. Try again. Also, the units on the left-hand side of your equation do not match the units on the right-hand side of your equation, thus indicating a mistake.
is the ARB solid or hollow?
formula for solid Anti Roll Bar , sway bar , stabilizer is -
1,125,000 x D⁴ / L x A
where D = bar outside diameter, L= effective bar length A+ effective arm length
  • Three dimensioning diagrams for anti-roll bars: aftermarket-type bar with labels A, D and L; hollow anti-roll bar cross-section with outer D and inner d; stock-type or mandrel bent anti-roll bar with labels L, D and A.
