Solve Infinite Limit: Find $\frac {1}{4}$
  • Thread starter Thread starter Asphyxiated
    Infinite Limit
The problem involves evaluating the limit as \( t \) approaches negative infinity for the expression \( \frac {\sqrt{t^{2}+2}}{4t+2} \). The discussion centers around understanding the behavior of the limit and the implications of the absolute value of \( t \) in the context of negative values.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the manipulation of the expression by factoring out terms and considering the absolute value of \( t \). There is discussion about the correct interpretation of \( \sqrt{t^2} \) and how it relates to the limit as \( t \) approaches negative infinity. Some participants question the necessity of multiplying by \( |t|/|t| \) and whether it affects the outcome.
The discussion is ongoing, with participants providing insights into the correct approach to take when evaluating the limit. There is recognition of mistakes made in earlier steps, and some participants express confusion about the proper manipulation of the expression. Guidance has been offered regarding the treatment of \( |t| \) and its implications for the limit.
Participants note the importance of understanding the behavior of the expression as \( t \) approaches negative infinity, particularly in relation to the signs of the terms involved. There is an acknowledgment of differing interpretations of the limit and the need for clarity in the steps taken to evaluate it.
Asphyxiated
[tex]\lim_{t \to -\infty} \frac {\sqrt{t^{2}+2}}{4t+2}[/tex]
Later in the problem I will use:
[tex]\epsilon^{+} \;\;\;\;\;\;\;and\;\;\;\;\;\;\; \epsilon^{-}[/tex]
to represent positive and negative infinitesimals, respectively.
So:
[tex]\lim_{t \to -\infty} \frac {\sqrt{t^{2}(1+2t^{-2})}}{4t+2}[/tex]
[tex]\lim_{t \to -\infty} \frac {t\sqrt{1+2t^{-2}}}{4t+2}[/tex]
[tex]\lim_{t \to -\infty} \frac {t\sqrt{1+2t^{-2}}}{t(4+2t^{-1})}[/tex]
[tex]\lim_{t \to -\infty} \frac {\sqrt{1+2t^{-2}}}{4+2t^{-1}}[/tex]
So at this point the limit is basically saying this:
[tex]\frac {1 + \epsilon^{+}}{4+ \epsilon^{-}}[/tex]
this is because the reciprocal of negative infinity squared is a positive infinitesimal and the reciprocal of negative infinity is a negative infinitesimal so the limit is:
[tex]\lim_{t \to -\infty} \frac {\sqrt{t^{2}+2}}{4t+2} = \frac {1}{4}[/tex]
My book states it should be -1/4 but I do not see why. Your adding a positive infinitesimal to 1 and subtracting it from 4, but that doesn't make the numerator or denominator negative, so what I am I missing?
Delete post
[tex] \sqrt{t^{2}} = \left| t \right| = \left\{<br /> \begin{array}{lcc}<br /> t & , & t \ge 0 \\<br /> -t & , & t < 0<br /> \end{array} \right. [/tex]
That too. So the above is a better answer. Multiply by |t|/|t| and look at the situation, ie. where the limit is going off to, if you have a problem like the one you have with a square root, etc. in order to see if you need a +t or -t.
No! You only made a mistake in step 3 where you took [itex]t^{2}[/itex] from the square root. According to my formula, you should have taken something else. Everything else follows from there.
You're right, I feel stupid now for not realizing my mistake from the beginning. They should have left the t^2 in there and multiplied the expression by |t|/|t| to take the t^2 away in the numerator and leave a -t to be multiplied through in the denominator and apply the limit to get the answer.
Could you possibly explain what it is that I was suppose to take out? The (1+2t^{-2})? cause that would be the only part to take out of the radical and I don't see that getting me to the correct solution.
@physicsman2
I don't see why I would need to multiply t/t by -t/-t to get them to cancel just because it is -infinity, t/t = t*t^-1 = 1 inherently, why is the multiplication necessary?
sorry, didnt notice the last post physicsman2,
so should i not have even factored out the t^2 and instead multiplied by |t|/|t| which is effectively -t because the limit is - infinity? I still don't see how it is solved though...
You solved it, though. When t < 0, |t|/t = -1, which is where the negative appears.
oh, i am pretty sure i got it then
Pretty much this.
Sorry for the confusion earlier, I wasn't thinking all that well until I was corrected.
Remember that |t| also equals sqrt(t^2). |t| can also equal either t or -t the way Dickfore showed. Since you want to take out a t^2 and cancel to apply the limit, you change |t| to sqrt(t^2) to bring it into the radical and divide. You would change the |t| in the denominator to -t because you're approaching -infinity, just as Tedjn showed. Divide and apply the limit, and you get -1/4
  • · Replies 31 ·
