Solve Kinetics Question: Zero Order Reaction at High Pressure
  • Thread starter Thread starter mooncrater
    Kinetics
3 replies · 2K views
mooncrater
The question says:
The decomposition of a gas on a surface follows the rate law : Rate is proportional to ##\frac {kP}{1+kP}##, where ##P## is the pressure and ##k## is a constant. Find the order of the reaction at high pressure.
In the solution they have said that since ##P## is high therefore ##kP>>>1## due to which rate is proportional to ##\frac {kP}{kP}=1## which means the rate is a constant so it is a zero order reaction. What I say is that since they don't known the value of ##k## how can they come to the conclusion that ##kP>>>1##? If we assume k to be equal to a very very small number such that ##1>>>kP## then their assumption fails, and the rate is not a constant.
So am I right about this thing or making a mistake?
Chestermiller said:
If doesn't matter what the value of k is. If you take a high enough pressure, the order will approach zero.
chet
But if we leave that proven part (I. e if pressure is increased order will tend towards zero) and use only this :
Rate is proportional to $$\frac {kP}{1+kP} $$
Then isn't the value of ##k## important?
