Solve Pelican's Initial Speed & Fish's Horizontal Distance
  • Thread starter Thread starter jbutl3r25
The discussion revolves around a physics problem involving projectile motion, specifically the scenario of a pelican dropping a fish from a certain height and calculating the fish's horizontal travel distance before hitting the water. The original poster describes their attempts to determine the pelican's initial speed and the subsequent horizontal distance traveled by the fish when dropped from a different height.
  • The original poster attempts to apply kinematic equations to find the horizontal distance traveled by the fish after dropping from a height of 3.3 m, based on their previous calculations. Some participants question the method used to calculate the time of freefall and suggest using specific kinematic equations.
Participants are actively engaging in clarifying the approach to solving the problem. Some guidance has been offered regarding the use of kinematic equations to determine the time of freefall and how to relate that time to the horizontal distance traveled. Multiple interpretations of the problem are being explored, particularly concerning the calculations involved.
The original poster mentions that their answer for the second part of the problem was marked incorrect by their homework service, indicating a potential misunderstanding or miscalculation in applying the physics principles involved.
jbutl3r25
Ok this is a follow-up type of question. The first problem was : A pelican flying along a horizontal path drops a fish from a height of 3.7 m. The fish travels 8.2 m horizontally before it hits the water below. What is the pelicans initial speed?
vx
dx 8.2
t
vfY
voY 0
aY -9.8
dY -3.7
t
I worked this out to eventually get to vx = 9.4, giving the pelican's speed.
Now the part that's giving me trouble is this:
If the pelican is traveling at the same speed, but only 3.3 m above the water, how far would the fish travel horizontally before hitting the water below? I used the same format that I did about, and switched the dY to -3.3 m...I got the answer and put that as my answer in the online homework service we use. It said the first part was correct, but this part is wrong. Anoybody see what I'm doing wrong?
You need to work out the time taken for the fish to freefall 3.3m using s = ut+1/2at^2
then put that time with the horizontal speed to get the horizontal distance.
help?
I have this same problem for my honors physics class and I was wondering what equation you used to get vx = 9.4?
The important point is that the fish's horizontal speed doesn't change - since no forces act horizontally.
So just use s = 1/2 g t^2 to get the freefall time and use that with the horizontal speed to get the horizontal distance travelled.
