Solving 2D moments about point O
9 replies · 7K views · last reply
majunee
(a) The moment the force, F, makes about O is 15 N-m clockwise, and θ = 30˚, find the magnitude of F.
(b) If the force F = 100 N, determine the angle θ so the force develops a clockwise moment about point O
of 20 N-m. Limit your answers to a range of 0º ≤ θ ≤ 90º.
I'm a little lost can someone please help me with how to set up equations so i can figure out the answers. Thanx
  • Diagram of a bent lever arm pivoting at point O on a y-x coordinate system, with a force F applied at the handle end at angle θ, a 50 mm vertical offset, a 300 mm arm length, and a 60° angle at the base.
welcome to pf!
hi majunee! welcome to pf! :smile:
start by completing the diagram …
continue the line of force backwards, and find its perpendicular distance from O :wink:​
thanx so is this correct so far
-15 KN-m = F[-(sin30°)-(50mm)-(300sin60°)]
hmm … you're going to need another hint:
call that corner "C"
draw the line G through C parallel to F
draw the two perpendicular lines from O to G and from C to F …
how long are they? :wink:​
Sorry I am really having trouble understanding the concept...
wouldnt 0-G be 300sin60 and c-f be 50 + xsin30
ahhh, you seem to be measuring vertical distances
no, to find the moment of a force, you need to measure distance(s) perpendicular to the line of the force :wink:
start again :smile:​
how? if force has continuing line of action shouldn't we measure along the yaxis which would be like i did?
why the y axis? :confused:
(are we using the same diagram? … the force is at 30°)
yes we are
so would it be -300sin60 + 300 cos 60 - 50 + xsin30 - x cos 30
and what is the "x" in your equation?
