How to solve a 2nd order pde with constant a?
  • Thread starter Thread starter maggie56
    2nd order Pde
To solve the second-order PDE 16d²u/dxdy + du/dx + du/dy + au = 0, a suggested method is to use the substitution u(x,y) = s(x)t(y), which allows for separation of variables. This results in two linear ordinary differential equations (ODEs) after rearranging and factoring the terms. The left side of the equation becomes a function of x only, while the right side becomes a function of y only, leading to the conclusion that both sides must equal a constant. The constant, denoted as C, acts as an eigenvalue determined by the PDE's boundary conditions. This approach provides a structured way to tackle the problem effectively.
maggie56
I have a pde,
16d2u/dxdy + du/dx + du/dy + au = 0 where a is constant.
I have tried to solve this pde using the substitutions x=e^t and y=e^s so t=ln(x) and s=ln(y) then finding
Du/dx= 1/x du/dt and du/dy= 1/y du/ds
For d2u/dxdy i am unsure if my answer is correct,
1/xy d2u/dsdt - 1/x du/dt - 1/y du/ds
When i substitute these into the pde i get 16/xy d2u/dsdt + au = 0
I could integrate this with respect to s and t but don't think that helps me.
Am i using the correct method here or is there a method that is better suited to my equation
Thank you for any help
Try setting u(x,y) = s(x)t(y) and separating the equation.
Sorry, not sure i follow, what do you suggest i could set them as?
If you substitute u(x,y) = s(x)t(y) into your PDE, you'll obtain
16 (ds/dx)(dt/dy) + (ds/dx) t + s (dt/dy) + a s t = 0
Rearrange & factor:
(dt/dy)[16 (ds/dx) + s] = -t [(ds/dx) + a s]
Separate the variables:
(dt/dy) / t = -[(ds/dx) + s] / [16 (ds/dx ) + a s]
The left side is a function of x only & the right side is a function of y only. The only way that can be so is if both sides are equal and constant. So
(dt/dy) / t = C
-[(ds/dx) + s] / [16 (ds/dx + a s] = C
That leaves you with two linear ODEs. C is an eigenvalue that will be determined by the PDE's boundary conditions.
For more info, check out
http://mathworld.wolfram.com/SeparationofVariables.html
or
http://en.wikipedia.org/wiki/Separation_of_variables
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 28 ·
