Solving a Complex Equation Using Binomial Formula with Cosine and Sine Functions
15 replies · 4K views · last reply
Bob19
Hello
I'm suppose to show
Given z^4 + z^3 + z^2 + z + 1 = 0 where
[tex]z = cos(\frac{2 \pi}{5}) + i sin(\frac{2 \pi}{5})[/tex]
by using the binomial product formula.
r^n - s^n
Is that then
if r,s = z then z^4 - z^4 = 0 ?
Sincerely and Best Regards
Bob
i don't see any binomial product formula in your post, i just see r^n-s^n, surely that should equal something...?
Theorem
[tex]r^n - s^n = (r-s) \sum_{j=0} ^{n-1} r^{j} s^{n-j-1}[/tex]
where r,s are numbers in the Ring R and n is a natural number.
I'm presented with the following polymial
z^4 + z^3 + z^2 + z +1 = 0
where [tex]z = cos(\frac{2 \pi}{5}) + i sin(\frac{2 \pi}{5})[/tex]
To show the above I'm told to use the theorem:
Do this then imply that
z^4 - z^4 = (z-1)(z^4 + z^3 + z^2 + z +1) = 0
/Bob
Bob19 said:
Hello
I'm suppose to show
r^n - s^n
Is that then
Bob
Yes, it is certainly the case that z^4- z^4= 0 no matter what z is!
But, also certainly, that is not the question you intended to ask.
It is true that r^n- s^n= (r- s)(r^(n-1)+ r^(n-2)s+ ...+ rs^(n-1)+ s^(n-1). (Although that is not what I would call the "binomial product formula.)
So if z^4 + z^3 + z^2 + z + 1 = 0, multiplying both sides by z-1,
z^5- 1= 0 ro z^5= 1 and so z is a "root of unity". Was that what you intended?
Bob19 said:
Theorem
good, now how can you get z^4+z^3+z^2+z+1 into a formula like that? setting r=z will help, now what about a choice for r?
[/quote]where [tex]z = cos(\frac{2 \pi}{5}) + i sin(\frac{2 \pi}{5})[/tex]
/Bob[/QUOTE]
the fact that z^4=z^4 implies that z^4-z^4=0.
your last line of maths is not an example of the binomial product formula
Hello Hall,
it is that thank Yoy :smile:
But there is a second equation which has caused me some trouble too:
z^8 + z ^ 6+ z^4 + z^2 +1 = 0
z is the same as in the first one, but how I get i simular result as in the first one? If I multiply left and right by (z-1). I don't get an equation on the form z^n = 1.
Any idears on how I solve this one?
Sincerley
Bob
all of the powers of z are even, aren't they,so it really is an equation in z^2,m isn't it?
yes but if I divide the equation with z^2 I get
z^4 + z ^ 3 + z ^2 + z + 1/z^2 = 0
how do You get z^ 2 from that?
Sincerely
Bob
Firstly dividing by z^2 won't help, and secondly, even if you did divide by z^2 that isn't the result.
Okay I misunderstood
I have now multiplied it by (z^(2) -1) and got
z^16 + z ^12 - 1 = 0 or z^16 + z^12 = 1
Am I on the right track now ?
Sincerley
Bob
why are you making it more complicated? when i said it was a polynomial in z^2 what did I mean by that?
Also, you're starting from the answer. you should not equate z^8+z^6+z^4+z^2+1 to zero to begin with since that is what you are trying to show.
let's use some different letters.
if i write
a^4+a^3+a^2+a+1
and
b^8+b^6+b^4+b^2+1
can you see a simple way to transform the second quantity into the first?
You meant that z^2 is a root for the polynomial ?
thereby (z^2)^4 + (z^2)^3 + (z^2)^2 +1 = 0
/Bob
if i write
a^4+a^3+a^2+a+1
and
b^8+b^6+b^4+b^2+1
z^2 is not a root of the polynomial, though two things are being conflated there. but you managed to get the correct notion about making it a polynomial in z^2
If I don't divide or multiply by z^2 and z^2 is not a root of the polynomial, how in God's name is it transformed into z^2 = 0 ??
The only way I can see that is
z^8 + z^6 + z^4 + z^2 +1 = z^8 + z^ 6 + z^4 + 1
and then get z^2 = 0
Sincerely
Bob
who said it was transformed into that?
you know that
w^4+w^3+w^2+w+1= (w^5-1)/(w-1)
that was the first thing you proved.
and you know that w=z^2 gives what you want to examine. and you know that z is a fifth root of unity.
incidentally, you do realize these are just geometric progressions?
Hi Matt and thank You,
Sorry that I have been slow to understand your surgestions.
Following the first equation,
then the second eqaution:
z^8 + z^6 + z^4 + z^2 +1 = (z^10 + z^8 + z^6 + z^4 + z^2)/(z^2)
Am I on the right path now?
Sincerely and Best Regards,
Bob
you know that
