Solving a complex numbered cubic equation
  • Thread starter PcumP_Ravenclaw
    Complex Cubic
4 replies · 2K views · last reply
PcumP_Ravenclaw
Solve the equation ## z^3 − z^2 + z − 1 = 0 ## first by inspection, and then by the
method described above. where Z is a complex number. (Alan F. Beardon, Algebra and Geometry)
The method described above is shown in the attachment.
The method is shown in the attachment.
Solve by inspection means to draw the graph of this equation and check where it intersects the x axis??
Shown in the attachment. the solution is 1 if i am not wrong
My algebraic solution is different. why? My attempt is also in the attachement.
Can you please also explain why there are six solutions for ## z ## when #z^3# has two solutions because of quadratic equation. cube root of any number has only one solutions which is the number itself. e.g. ## \sqrt[3]{-1} = -1*-1*-1 or \sqrt[3]{1} = 1*1*1## so cube root only gives one solution then what do they mean by six solutions??
danke...
  • Printed textbook page from Beardon's Algebra and Geometry, section 3.6 on cubic and quartic equations, with yellow highlights. It derives the substitution p(z) = z^3 + 3bz - c and notes that the six values of zeta give at most three distinct roots of p.
  • Graph of y = x^3 - x^2 + x - 1 on a grid from x = -10 to 10 and y = -50 to 50, crossing the x-axis once at x = 1, with a slider panel for coefficients a, b, c and d.
  • Handwritten working solving z^3 - z^2 + z - 1 = 0 by substitution z^3 = y, giving y^2 + y - 1 = 0, then y = 0.618034 or -1.618034, and z values including 0.851800 and -1.173985 with reciprocal terms, ending near 0.01114799782.
By inspection means just that: look at the terms of the equation and substitute some guesses which can be evaluated using mental arithmetic.
For the equation in the OP, looking at how the signs of the terms alternate, guessing that z = 1 is a solution is a solid hunch, since the magnitudes of z, z2, and z3 are all 1.
"By inspection" often means just trying simple numbers. What do you get if you put z= 1 into the equation?
Or you could look at the fist two terms, then look at the second two terms and notice these paddies have, er, a something in common. ;)
It does not say there are six solutions for z. It says there are six solutions for ##\zeta##, but pairs of these produce the same value for z.
