Solving a Nonlinear Differential Equation Using Bernoulli's Method
5 replies · 2K views · last reply
syj
[itex]\frac{dr}{dt}=r(u-r)[/itex]
i rewrote this as [itex]\frac{dr}{dt}-ur=-r^2[/itex]
i think this is like bernoulli's equation
so i let [itex]w=\frac{1}{r}[/itex] so that [itex]r=\frac{1}{w}[/itex]
this gives me
[itex]\frac{dr}{dt}=-1w^{-2}\frac{dw}{dt}[/itex]
so now i have
[itex]-w^{-2}\frac{dw}{dt}-uw^{-1}=-w^{-2}[/itex]
if i divide by [itex]-w^{-2}[/itex]
then i get a linear differential equation
[itex]\frac{dw}{dt}+uw=1[/itex]
the integrating factor is [itex]e^{ut}[/itex]
so i get [itex]w=\frac{1}{u}+w_0e^{-ut}[/itex]
from my definition of [itex]w[/itex] i have [itex]w_0=\frac{1}{r_0}[/itex] and [itex]w=\frac{1}{r}[/itex]
so i get [itex]r=\frac{ur_0}{r_0+ue^{-ut}}[/itex]
is this right?
check by differentiating and comparing to the original DE
note this equation is separable, so you could do it by direct integration
please explain how i would solve by separation.
thanks
[tex] \frac{dr}{dt}=r(u-r)[/tex]
gives
[tex] \int \frac{dr}{r(u-r)}=\int dt[/tex]
though even if you can solve the integral (partial fractions may be a good start) it may be difficult to get into an analytic function for r(t)
[tex]\frac{dr}{dt}= r(u-r)[/tex]
with u constant.
[tex]\frac{dr}{r(u-r)}= dt[/tex]
Integrate the left side with respect to r and the right side with respect to t.
( I really hate it when lanedance gets in one or two minutes ahead of me but to have him first with exactly the same timestand- arrrgh!)
ok so i get
[itex]\frac{ln(r)-ln(r-u)}{u}=t[/itex]
which i then manipulate (or try to at least ) to get:
[itex] ln\frac{r}{r-u}=ut[/itex]
if this is correct then i think i can do:
[itex] \frac{r}{r-u}=e^{ut}[/itex]
i know something is wrong cos i don't have [itex]r_0[/itex]
im working through an example in jordan and smith (nonlinear ordinary differential equations)
so i know what the answer should be, I am trying to get to it tho.
please please correc this.
