Solving a Nonlinear Differential Equation Using Bernoulli's Method
syj
\frac{dr}{dt}=r(u-r)
i rewrote this as \frac{dr}{dt}-ur=-r^2
i think this is like bernoulli's equation
so i let w=\frac{1}{r} so that r=\frac{1}{w}
this gives me
\frac{dr}{dt}=-1w^{-2}\frac{dw}{dt}
so now i have
-w^{-2}\frac{dw}{dt}-uw^{-1}=-w^{-2}
if i divide by -w^{-2}
then i get a linear differential equation
\frac{dw}{dt}+uw=1
the integrating factor is e^{ut}
so i get w=\frac{1}{u}+w_0e^{-ut}
from my definition of w i have w_0=\frac{1}{r_0} and w=\frac{1}{r}
so i get r=\frac{ur_0}{r_0+ue^{-ut}}
is this right?
check by differentiating and comparing to the original DE
note this equation is separable, so you could do it by direct integration
please explain how i would solve by separation.
thanks
<br /> \frac{dr}{dt}=r(u-r)<br />
gives
<br /> \int \frac{dr}{r(u-r)}=\int dt<br />
though even if you can solve the integral (partial fractions may be a good start) it may be difficult to get into an analytic function for r(t)
\frac{dr}{dt}= r(u-r)
with u constant.
\frac{dr}{r(u-r)}= dt
Integrate the left side with respect to r and the right side with respect to t.
( I really hate it when lanedance gets in one or two minutes ahead of me but to have him first with exactly the same timestand- arrrgh!)
ok so i get
\frac{ln(r)-ln(r-u)}{u}=t
which i then manipulate (or try to at least ) to get:
<br /> ln\frac{r}{r-u}=ut<br />
if this is correct then i think i can do:
<br /> \frac{r}{r-u}=e^{ut}<br />
i know something is wrong cos i don't have r_0
im working through an example in jordan and smith (nonlinear ordinary differential equations)
so i know what the answer should be, I am trying to get to it tho.
please please correc this.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
