Solving a normal distribution problem
18 replies · 21K views
6021023
Assume X is normally distributed with a mean of 10 and a standard deviation of 2. Determine the value for x that solves P(-x < X - 10 < x) = 0.95
P(X < x) = P(Z < z) = P(Z < (x - mean)/stdev)
P(10 -x < X < 10 + x) = 0.95
P(X < 10 + x) - P(X < 10 - x) = 0.95
P(Z < (10+x-10)/2) - P(Z < (10-x-10)/2) = 0.95
P(Z < x/2) - P(Z < -x/2) = 0.95
That's as far as I get, and then I don't know what to do next, or if what I did was correct.
I hope you have some normal tables for this. You are making some mistakes in that P(X < 10 + x) - P(X < 10 - x) = 0.95 isn't true. First of all, what is the distribution of X-10?
Can you use symmetry in any way to simplify P(-x < X - 10 < x)? After that can you make your distribution N(0,1)?
If you have any problems on these then give me a shout :)
Is P(-x < X - 10 < x) the same as P(10 -x < X < 10 + x)?
Hi Mark. Is P(10 -x < X < 10 + x), the same as P(X < 10 + x) - P(X < 10 - x)?
So if P(10 -x < X < 10 + x) is the same as P(X < 10 + x) - P(X < 10 - x), then if P(-x < X - 10 < x) = 0.95 then does that mean that P(X < 10 + x) - P(X < 10 - x) = 0.95?
That works for me. I got into this late, but I can't see how Focus's comment in post 2 could be correct.
So I guess that what I have down so far is correct, right? It appears that there is symmetry where I left off at P(Z < x/2) - P(Z < -x/2) = 0.95. Could I then do the following?
2[P(Z < x/2) - P(Z < 0)] = 0.95
Yeah, -x/2 and x/2 are like -a and a. I drew those points on a bell curve and saw the symmetry.
So would the following be correct?
P(Z < x/2) - P(Z < 0) = 0.475
P(Z < x/2) - 0.5 = 0.475
P(Z < x/2) = 0.975
x/2 = 1.96
x = 3.92
Looks good. There are some rules of thumb you can use for N(0, 1) distributions:
Probability within 1 sigma of the mean (i.e., -1 < z < 1), [itex]\approx[/itex] .68
Probability within 2 sigmas of the mean, [itex]\approx[/itex] .95
Probability within 3 sigmas of the mean, [itex]\approx[/itex] .99+
Your x values are a little under 2 s.d. away, so the probability/area should be around .95, which is right on the money for your problem.
What's an N(0, 1) distribution? Does that just mean normal distribution? What does the 0 and the 1 mean?
Sorry. That is just notation for the standard normal distribution: mean = 0, and standard deviation = 1. Your original distribution was N(10, 2).
So can I use that checking probability trick for N(0,1) distributions for the N(10,2) distribution? Here the z value is 1.96, which is just under 1 s.d. away.
The idea is that you can transform a random variable X that is N(mean, sd) to a z distribution (i.e., N(0, 1)) in this way:
z = (x - mean)/s.d.
You can go the other way, too:
x = z*s.d. + mean
Any probability written in terms of X can be rewritten in terms of z, which is preferable, since there are tables of z values.
You are making this much too complicated. You can't justify the step for P(X < 10 + x) - P(X < 10 - x) = 0.95. X-10 is normal with mean zero and standard deviation 2. You can use the symmetry about zero to say that's the same as 2P(X-10<x). I'll let you finish it off :)
Sure he can. The expression above represents the probability that X lies between 10 - x and 10 + x.
We're way past that. You must not have read the other posts in this thread.
If you think about it at all, 2P(X - 10 < x) is larger than 1 if x < 10, so this is not a helpful start.
Sorry you are right I'm way off the ball, I meant to say 2P(X - 10 < x)-1.
