Solving a pH Change After Adding Sulfuric Acid to Sodium Hydroxide
The discussion focuses on calculating the new pH after adding 36.00 mL of 0.0200 mol/L sulfuric acid to a 50.0 mL sodium hydroxide solution with an initial pH of 12.50. Participants confirmed the correct approach involves determining the concentration of hydroxide ions [OH-] using the formula 10^-pH, leading to a concentration of 3.16 x 10^-2 mol/L. The reaction equation is established as 2NaOH + H2SO4 → Na2SO4 + 2H2O, and the importance of calculating moles and using an ICE (Initial, Change, Equilibrium) table is emphasized for accurate pH determination.
  • Understanding of pH and pOH concepts
  • Familiarity with acid-base neutralization reactions
  • Knowledge of molarity and concentration calculations
  • Ability to construct and interpret ICE tables
  • Learn how to calculate pH from hydroxide ion concentration
  • Study the principles of acid-base titration
  • Explore the concept of limiting reagents in chemical reactions
  • Review the use of ICE tables in equilibrium calculations
Chemistry students, educators, and anyone involved in chemical calculations or acid-base chemistry will benefit from this discussion.
arctic_viper
A 50.0 mL aqueous solution of sodium hydroxide has a pH of 12.50. If 36.00 ml of 0.0200 mol/L sulfuric acid is added to this sodium hydroxide solution, what will be the new pH of the resulting solution? Assume that the temperature stays constant at 25C, and that the volumes are perfectly additive.
2. The attempt at a solution
I tried looking at a similar post -->https://www.physicsforums.com/threads/quick-ph-calculation-please-verify.753708/#post-5639696, (I have no idea how he/she did it)
I've tried doing 10^-12.50 to get [OH-] but I'm not sure it's right.
3. I have no idea what to do to solve this question. Please help, and thank you. :D
What you did was more or less a correct first step - that should give you the concentration of NaOH.
Now write the reaction equation.
So,
2NaOH(aq) + H2SO4(aq) ---> Na2SO4(aq) +2H2O(l) ?
How many moles of the NaOH were present? What is the limiting reagent?
Please try to apply what you know to the problem, if you are going to just do whatever you are told you will never learn how to move ahead.
Will there is a way of being more sure one way or the other. In a neutral pure water [OH-] is 10-7. So for an NaOH solution does 10-12.5 sound reasonable?
It would be nice and helpful also to alingy him/herself if he/she came back and explained
Are you familiar with the fact that $$log[H^+]+log[OH^-]=-14$$ and that $$pH=-log[H^+]$$
Yes, sorry, I had my exam yesterday and was really tired. But I did find the concentration by doing the following.
14-12.50 =1.50
then 10^-1.50 to get 3.16x10^-2
Then I divided that by the 50.00ml of water to find initial moles.
After doing that I made an IRF table..I also found the moles of H2SO4 by using the given information. I pretty much just solved the IRF table. (I'd have to look at my notes again to see what else I did.) But I think I undertand how to solve the problem. Thanks and sorry.
14-12.50 =1.50
You should multiply by 0.05 liters of water to find the initial moles. The 0.0316 has units of moles/liter.
Ya that's pretty much what I did. I converted ml to liters by dividing by 1000. After that I multiplied the [OH-] by the L to get the moles of [OH-]
Checking for reasonableness and orders of magnitude needs to become a second-nature habit for chemical calculations. Even if you were partly along the right lines humourless Profs etc. may give you no credit at all or even less if your answer is out by 10 orders of magnitude! :oldsmile:
What do you mean by orders of magnitude?
Factors of 10
epenguin said:
Factors of 10
I see. Thanks.
  • · Replies 16 ·
  • · Replies 20 ·
