Solve y'' - (y')²/y + 2(y')²/y² - (y')⁴/y⁴ = 0 with y(0)=1, y'(0)=0
33 replies · 4K views
docnet
solve the equation with y = 1, y' = 0 at t = 0
y'' - ((y')^2)/y + (2(y')^2)/y^2 - ((y')^4)/y^4 = 0
Hi all, if anyone could help me solve this 2nd order differential equation, it would mean a lot.
Problem:
Solve the equation with y = 1, y' = 0 at t = 0
I have never solved an ODE of this kind before and I am not sure where to start. Wolfram and Symbolab calculators will not give an answer.
Thank you.
Not sure if this will be helpful but check if the ansatz $$y=e^{kt}$$ is a solution for the proper values of ##k##.
EDIT: NVM I was wrong, the ansatz doesn't satisfy y'(0)=0, unless we have ##k=0## but then the solution is trivial ##y=1##. That is ##y(t)=1## is one solution for sure (you can easily verify it satisfies the differential equation given).
It would be interesting to see if for the moment we forget the initial condition y'(0)=0 and see what this ansatz gives if it is plugged to the ODE.
The idea behind this ansatz is that it satisfies $$(\frac{y'}{y})^n=k^n$$ and also that $$y''=k^2y$$ so the ODE might be turned into an algebraic equation for k.
I'd say that the only way to solve a differential equation, at least the only way that is commonly taught, is to know the answer! Or at least to know the sort of answer for things like it. And then with the particular case you hammer it into the shape that fits (and don't forget to check the answer which is very simple to do but often forgotten).
And then there is the Polya principle "have you ever seen anything like it?". For instance there is a trick that comes up often in dynamics - what is the derivative of (yy')? I haven't got the answer but I would play around with that, you do have to play around a bit.
Delta2 said:
then the solution is trivial y=1.
Quite so. What makes you think there are others?
I don't know to be honest at start I thought for some reason it was linear (which isn't of course) and we know linears of order n have at least n linearly independent solutions but it isn't linear so i don't know
If we relax the initial conditions then I think one solution is $$y=ce^{\pm\sqrt{2}t}$$
Thank you.
Equations of the form ##f(y,y',y'')=0## can be reduced to a first-order in y and y' by letting ##y'=p## so that ## y''=p\frac{dp}{dy}##. Maybe see if this helps. Also look up "independent variable missing" in DE text for some additional info. Wouldn't hurt too to just solve it numerically via NDSolve in Mathematica to at least see what it looks like.
At t=0, y=1 and y'=0. Plugging into the equation also gives that y''=0 at t=0. If y'(0)=0 and y''(0)=0, then what does that tell you?
Yes, my hint in post #4 was probably too subtle.
I am sorry all, my original post included a bad typo in the equation. I am not experienced at typing equations into the computer.
Here is the entire question and my work leading up to the differential equation in part (f.) The professor warned us ahead of time the ODE for the geodesic may be difficult.
I believe the last line is the correct ODE to solve for, which I was unable to solve using any methods I was familiar with. Looking at the plot of the geodesic, it looks like the V component asymptotically approaches 1 and -1 at infinite and -infinite t. the U component only exists for > 0 and is also symmetric around t = 0. Does anyone know of any similar ODE examples to learn from?
I think the best way to proceed is to use the hint from @aheight in post #6, and replace u'' with u' du'/du. This at least converts the equation to a first order equation.
... and beyond that, u'=u cos(θ) looks useful.
Hm... I tried solving the expression u' = u cos(Θ) and obtained u = C exp [sin(Θ) ] which doesn't seem to correspond to a solution for our problem.
No, I mean after replacing u'' with u' du'/du, substitute for u' using that relationship to get an ODE in x and θ.
After doing the substitutions we ended up with the following equation
where t = θ and u = y.
The 1st order ODE could not be solved by using Symbolab. Is there a mistake??
docnet said:
So we substitute u' = ucosΘ
and substitute u = (1/2)u2cosΘ obtained by integrating u'
and substitute du'/du = cosΘ obtained by differentiating u'
and ended up with the following oth order equation that cannot be solved for u.
https://www.physicsforums.com/attachments/274852
Should we substitute u' = ucosΘ and leave u and du'/du alone?
edit: the expression u = (1/2)u2cosΘ does not make any sense. I'll spend some time before posting a followup.
You have ##\ddot u=\frac{\dot u^2}u+\frac 1{u^2}(1-\frac{\dot u}u)^2##.
Writing ##x=u, y=\dot u, y'=\frac{dy}{dx}, \ddot u= \frac d{dt}y=\frac d{du}y\frac{du}{dt}=yy'##:
##x^2yy'=xy^2+(1-\frac{y^2}{x^2})^2##
If all that looks right to you, substitute ##y=x\cos(\theta)## and see what simplifies.
So we have
which simplifies to
then
which gives y = x in our substitution
and
with the solution
and
with the solution
with c1= 1 and c = 0.
May I continue solving the next part of the problem?
haruspex said:
No, θ is a variable, so what does y' become?
Differentiating y with respect to x gives us y'=cosθ which gives
The first two terms cancel and we are left with the equation in θ as before.
when we differentiate y with respect to theta we have y' = - xsinθ which gives us an equation which is difficult to solve for x or θ.
We could differentiate with respect to x and theta using the chain rule, and it results in another equation which I was unable to solve for x or θ.
No it doesn’t. θ is a variable, as in θ=θ(x).
I'm getting
which simplies to
whose solution is Θ(x) = 0
May I move onto the next part?
haruspex said:
You have made a mistake in expanding (1−y2x2)2.
Doh! yes I did, and I just fixed my mistake.
It finally comes out to
whose solutions are
where y(t) has been replaced with Θ(x) and t with x.
Which can be simplified to ##x^4\sin(\theta)\cos(\theta)+\sin^4(\theta)=0##, hence ##x^4\cos(\theta)+\sin^3(\theta)=0##, unless sin() is 0.
docnet said:
whose solutions are
Defining a different y from what we had earlier is confusing.
At t=0, u=x=1, ##y=\dot u=0##, ##\cos(\theta)=0, |\csc(\theta)|=1##.
I get ##(\dot u)^2=\frac{2u^5-2u^2}{5u^3-2}##, leading to a nasty-looking integral.
Is anyone familiar with the surface corresponding to our metric
It could give us an idea of what the geodesic is.
It looks like the surface stretches the du vector to infinity at u = 0 and shortens the dv vector to 0 at u = 0.
Dear all,
There is another error in our differential equation.
Starting over from part e) we solve the following equation for (dv/dt)2.
giving
and substitute it in the following equation
giving
Which offers no clear way to solve. We examine the following expression from part d).
which makes
which implies
for some constant c. solving,
substitute into the first equation to get
which makes
I think this way is not easy.
The expression
has the solution
and
For the v component of the geodesic, we plug in
into the unit speed equation
giving
and
We then integrate to give
and
which is incorrect judging from the following plot in the uv plane
but I think we are getting closer to the correct solution.
What course is this? Differential geometry?
