Solving a Tough Math Problem: Any Ideas?
  • Context: Graduate
  • Thread starter Thread starter al-mahed
    Ideas
The discussion centers on the mathematical problem of finding integer solutions for the equation 2n + 3 = mm, where m is an odd integer. Key insights include that for n > 1, m must be of the form 4x + 3, and the only trivial solution identified is (n, m) = (0, 2). Participants concluded that m cannot be even, as it leads to contradictions regarding parity and modular arithmetic, specifically that mm is not a perfect square when m is odd.
  • Understanding of modular arithmetic, specifically congruences.
  • Familiarity with properties of odd and even integers in number theory.
  • Knowledge of perfect squares and their characteristics.
  • Basic experience with mathematical problem-solving techniques involving exponents.
  • Explore the properties of odd perfect squares and their congruences.
  • Investigate the implications of modular arithmetic in solving exponential equations.
  • Study the behavior of the equation 2n + 5 = m2 for integer solutions.
  • Learn about the use of the Euler's totient function in modular equations.
Mathematicians, number theorists, and students interested in advanced problem-solving techniques in number theory, particularly those focusing on exponential equations and modular arithmetic.
al-mahed
I came across this problem on another forum. Seems to be very tough.
The only trivial facts are:
m is of the form 4x+3 for n>1
a trivial solution (n,m) is (0,2)
for n even, m^m-1 is divisible by 3
for n odd, m^m-2 is divisible by 3
any ideas?
To input something in this discussion, aside from the trivial solution, m can't be even. If m was even, the parities don't match up, so you know that m has to be odd. I'll try to figure something more later.
If you are right that "m is of the form 4x+3 for n>1", then the only solution is the trivial solution.
M can not be even, since 2^n+3 is always odd. but all odd squares are congruent to 1 Mod 4, so that2^n congruent to 0 for n greater than one. So he only possibility is m^2 = 5, which is not a square.
Now if we try the case of 2^n+5 =m^2, we have a solution for n=2, m=3. Are there more? No, why?
M can not be even, so it is odd. All such square are congruent to 1 Mod 8. So we have
2^n+5=1+8K, or 2^n+4 = 8K, which reduces to 2^(n-2) + 1 =2K. This is possible only for the previously described case n-2 = 0.
robert
I didn`t understand what you did, m is not necessarely of the form 8t+1, m^m is not a square as the exponent m is odd, 3^3 - 1 is not divisible by 8 (and not by 4 neither), 5^5-1 is not divisible by 8, and infinitely many other examples.
jgm340
when n > 1, m is of the form 4x+3
2^1+3=5=4+1
2^2+3=7=4+3
2^3+3=11=4*2+3
2^4+3=19=4*4+3
and so on
All odd squares are of the form 8K+1. (2n+1)^2 =4n^2+4n+1 =4n(n+1)+1. I am also looking at the case not for 3, but for 5: 2^n+5 = m^2.
I know this fact about perfect odd squares, the thing is: m^m is NOT a perfect odd square, m is odd, so we have (2k+1)^{(2k+1)}=(2k+1)^{2k}(2k+1), a square times a non square (only if m is a square itself)
and moreover, 2^n+3=2^n+2+1=2(2^{n-1}+1)+1, it cannot have the form 4r+1
ps: why are you trying to solve 2^n+5=m^2? it is not the original problem! but if you are really interested on it, you`ll find infinitely many solutions
What are the solutions to 2^n+5 = m^2? There is some real misunderstanding here.
hi robert
as for 2^n+5=m^2\ ==>\ 4(2^{n-2}+1)+1=m^2=4k(k+1)+1, in fact there is not infinitely many solutions as I prematurely said, n = 2 is the only solution, as k(k+1) is always even and 2^{n-2}+1 is even only for n = 2
going back to the original problem, I don`t understand your solution since m^m is never a square, could you please elaborate it more?
cheers
m=4 and n=3 is the only solution.
EDIT: Nevermind, I misread the problem.
al-mahed said:
hi robert
cheers
Such problems are normally worked by making the assumption there is a solution, i.e. that m*m is a perfect squre, that is an integral square.
Ok, let`s put into these terms: considering a natural n >0, and (hence!) an odd integer m, find solutions to 2^n+3=m^m, or prove there is any
Isn't m^m m to the mth power not m*m
I see that, as is frequent, I did not read the original problem correctly.
it happens with me all the time! to avoid further mistakes we are talking about 2^n+3=m^m
I think we can work it out using a^{\varphi (m)}\equiv\ 1\mod m
as m is not divisible by 2, and \varphi (2^n)=2^{n-1} we have
\large\ m^{2^{n-1}}\equiv\ 1\mod 2^n, but \large\ m^m\equiv\ 3\mod 2^n, hence
\large\ m^{2^{n-1}}\equiv\ m^m-2\mod 2^n
the font is too small, in case you cannot see the exponet properly I was trying to say that (now I modified some things):
\large\ (m^2)^{n-1}\equiv\ 1\ mod\ 2^n\ ==>\ m^{2^n}\equiv\ m^2 \ mod\ 2^n\ ==>\ m^{(m^m-3)}\equiv\ m^2\ mod\ 2^n
then m^2[m^{(m^m-5)}-1]\equiv\ 0\ mod\ 2^n\ ==>\ m^{(m^m-5)}\equiv\ 1\ mod\ 2^n
I don`t know exactly how to proceed from here, but m^m-5 cannot be a primitive root, otherwise it would imply (by the theorem of primitive roots) that m^m-5 | 2^{n-1}, and that`s not true for n> 1 since 2^n-2=m^m-5
just to point ouy that I made a terrible mistake
\large\ m^{2^{n-1}}\equiv\ 1\ mod\ 2^n\ ==>\ m^{2^n}\equiv\ m^2 \ mod\ 2^n
is false, the correct is
\large\ m^{2^{n-1}}\equiv\ 1\ mod\ 2^n\ ==>\ m^{2^n}\equiv\ 1 \ mod\ 2^n
since (m^2)^{n-1}\neq\ m^{2^{n-1}]
for instance 2^(2^3) = 2^8 = 256
and (2^2)^3 = 4^3 = 64
2^n+3 = m^m, then 2^n +4 = m^m+1 = (m+1)(1-m+m^2-+++m^(m-1)). We know m is odd, and since the later part of the factorization is odd, we have 4 and only 4 divides m+1, so m==3 Mod 8.
  • · Replies 21 ·
  • · Replies 26 ·
  • · Replies 41 ·
  • · Replies 17 ·
