Solving a Trigonometric Equation for Cos (x)
melissax
Hi, may you help me?
I have a question I solved but couldn't ended.
If cos(x)+5Sec(x)=1.1 then Cos(x)=?
2Cos(x)+5Sec(x) =11/10
2Cos(x)+5/Cos(x)=11/10
2Cos(x)*Cos(x)+5=11/10*Cos(x)
2Cos^2(x)+5=11/10*Cos(x)
2Cos^2(x)-11/10-Cos(x)-5=0 then i used delta=b^2-4ac
then i found delta=-4.79
X1=-b+sqrt(delta)/2a
then i found x1=2.19 and x2=-b-sqrt(delta)/2a but as i learnd answer is 0.5 where is the my mistake? Thank you
In-between these two lines, you have copied incorrectly. Where is the 2 coming from? Is that in the original problem or not?
You have made another error here: $(11/10)\cos(x)$ became $(11/10)-\cos(x)$.
You need to be more careful when you go from one line to the next. Pretend someone's holding a gun to your head and will fire if you make a mistake!
For the original problem, I get complex values for $\cos(x)$. Can you please post the original problem verbatim?
question is "2cos(x)+ 5sec(x)=1.1" problem isn't wrong.
Correct but can you help to solution?
In your original post you wrote the problem as "cos(x)+5Sec(x)=1.1" then you switched the "cos(x)" to "2cos(x)" on the next line. We can't tell if this is a math mistake which we need to explain or just a typo. I'm going to guess it's a typo.
[math]2\cos(x)+5\sec(x)=1.1[/math]
Multiply everything by $\cos(x)$ and you get
[math]2\cos^2(x)+5=1.1\cos(x)[/math] or [math]2\cos^2(x)-1.1\cos(x)+5=0[/math]
This has a quadratic form to it. Let $u=\cos(x)$ and rewrite the above equation as
[math]2u^2-1.1u+5=0[/math]
Can you make progress from here?
