Solving absolute value inequalities with |x-2| ≥ 4
  • Thread starter Thread starter jvignacio
    Inequalities
6 replies · 3K views
jvignacio
hey guys just checking if this is correct...
|x-2|(greater than and equal to) 4
= -2 (greater than and equal to) x (greater than and equal to) 6
is this correct? thanks u
and
1 (less than or equal to) | x + 2 | (less than or equal to) 4
= -1 (less than or equal to) x (less than or equal to) 2
correct? thank u
If you have
[tex] |x| \le A[/tex]
then
[tex] -A \le x \le A[/tex]
but if you have
[tex] |x| \ge A[/tex]
then
[tex] x \le -A \text{ or } x \ge A[/tex]
statdad said:
If you have
then
but if you have
then
so my less than or equal to is correct but other is wrong ?
yes - think about the number line. The absolute value of a number shows how far from [tex]0[/tex] a number is. If you have (just to make up some numbers)
[tex] |x| \le 9[/tex]
the number [tex]x[/tex] is at most a distance of nine from zero. Looking at the number line, that means that it must be true that
[tex] -9 \le x \le 9 [/tex]
However, if
[tex] |x| \ge 4 [/tex]
then [tex]x[/tex] is at least four units from zero. Again, looking at the number line, this means that
[tex] \text{Either} x \le -4 \text{ or } x \ge 4[/tex]
By the way, if your inequalities are either [tex]<[/tex] or [tex]>[/tex], the same type
of steps are used.
Does this help?
You originally said "= -2 (less than or equal to) x (less than or equal to) 6" which has two "less than or equal to"s. Both are wrong.
The best way to solve a complicated inequality is to solve the equation first. To solve [itex]|x- 2|\ge 4[/itex], first solve |x- 2|= 4 which reduces to x- 2= 4 or x- 2= -4 and has solutions x= 6 and x= -2. The point is that, since |x-2| is a continuous function, it can only change from "< 4" to "> 4" and vice-versa where it is equal to 4. The two points, x= -2 and x= 6, divide the real number line into 3 intervals and |x-2| must be either greater than or less than 4 throughout each interval. Checking a single value in each of x< -2, -2< x< 6, and x> 6 will tell you which is ">" and which is "<".
ahh so the solution is all 3 intervals?
should i do it the same way to solve
1 (less than or equal to) | x + 2 | (less than or equal to) 4 ?
i got the answer for |x-2|(greater than or equal to) 4
= x (less than or equal to) 2 or x (greater than or equal to) 6?
