Solving an Annoying Equation with Trigonometry and Constants
  • Context: Graduate
  • Thread starter Thread starter latentcorpse
20 replies · 5K views
latentcorpse
(dx/dt)^2 = (Mgh/A)*(2x-1)*(1-x)^2
where x=cos (theta)
and M,g,h and A are all constants
the solution is
sec(theta) = 1 + sech(sqrt(Mght/A))
if u can do it then could u please list your full answer cos i can get quite far into it and then the sech thing just confuses me
i think it involves using the weierstrass elliptic p function
HELP?!
the solution is
Hi latentcorpse! :smile:
Since they give you the answer :wink::
Hint: substitute y = 1/x - 1, and you get … ? :smile:
i forgot to mention that x = cos (theta)...my bad
also i can't get your substitution to work mainly because i don't see how that helps with the sech - i have little experience with sech so you might need to explain a bit more deeply how your getting that answer to work.
cheers guys
also i missed out the t.
ignor that first post.
here we go:
the solution is
sec(theta) = 1 + sech((sqrt(Mght/A))t)
where x = cos theta
cheers guys
Substitute y = 1/x - 1, and show us what you get.
That'll give you something which you can conveniently take the square-root of.
Just try it! :smile:
ok, if i try y=1/x - 1, then x=1/(y+1) and dy = -x^(-2) dx so dx = a x^(2) dy
this means dx/dt = sqrt(Mgh/A) (2x-1)^(0.5) (1-x)
becomes
- [(y+1)^(-2) dy]/[(((2/y+1)-1)^(0.5))(1-(1/y+1))] = (mgh/A)^(0.5) t
which gives me the argument of the sech term on the right side but i can't get the rest out!
(have a square-root: √ :smile:)
latentcorpse said:
[(y+1)^(-2) dy]/[(√((2/y+1)-1))(1-(1/y+1))] = √(mgh/A) t
Yes, but why have you stopped there? :confused:
What is (2/y+1)-1?
And what is 1-(1/y+1)? :smile:
well if y=1/x - 1 then
x = 1/(y+1)
and so y+1 = 1/x
then
(2/(y+1))-1 = 2x-1 = 2*cos(theta) - 1
and 1 - 1/(y+1) = 1 - x = 1 - cos(theta)
and then cos(theta)=1/(y+1), we have -sin(theta) d(theta) = -(y+1)^(-2) dy, giving
-[sin(theta) d(theta)]/[((2cos(theta)-1)^(0.5))(1-cos(theta)] = (Mgh/A)^(0.5) t
but how does this help us to integrate? i still can't see how the LHS works?
x = 1/(y+1)
and so y+1 = 1/x
then
Forget theta … it isn't in the question, and it isn't really in the answer (sectheta is just 1/x).
And forget x … the whole point of substituting y for x is to get away from x!
In terms of y:
(2/y+1)-1 = … ?
And 1-(1/y+1) = … ? :smile:
ok well i can't see any way of rearranging them other than factorising y+1
so that
(2/(y+1)-1)^(0.5) = (y+1)^(0.5)[1-y]^(0.5)
and,
1-1/(y+1)=(y+1)[(y+1)y]
and then substituting in and collecting these(y+1) terms with that one already on the numerator we get
-dy/[(1-y)^(0.5) (y+1)^(0.5) y]
now what?
also i see that sec(theta) is just 1/x but i think the reason I am finding this so hard is because I am looking so hard for where the sech term is going to come out
latentcorpse said:
… and then substituting in and collecting these(y+1) terms with that one already on the numerator we get
now what?
(hmm … what happened to that √ I gave you? :confused:)
Now write that as -dy/y√(1- y2). :smile:
Then make the obvious substitution. :smile:
ok
my bad about the root sign and damn i just realized i forgot to copy it again
so the obvious substitution would be some trigonometric function because of that
(1-y^2)^(0.5) term
now by y=1/x - 1 i get y=sec(theta) - 1 but that mucks things up
so i tried just y = cos(theta)
giving dy=-sin(theta) dtheta
then our LHS rearranges to
[sin(theta) dtheta]/[cos(theta) sin(theta)]
which is just the integral of sec(theta) dtheta
and the integral of sec is ln( sec(theta) + tan(theta) ) and surely i want something with a sech^(-1) in it so that i can get my sech(sqrt(Mgh/A)t) term on the RHS.
Yes, when you have a √(1 - y2), the usual substitution is either sin or cos, because sin2 + cos2 = 1.
But you can also use either sech or tanh, because sech2 + tanh2 = 1 also.
As you say, using cos gives you ln (sec + tan), which is really awkward.
So try sech intead of cos, and see what you get! :biggrin:
ok
well if y = sech(theta), dy = -sech(theta) tanh(theta) dtheta
and 1-y^2 = [tanh(theta)]^2 and so the denominator is sech(theta) tanh(theta)
then -dy/[y(1-y^2)^(0.5)] becomes
[sech(theta) tanh(theta) dtheta]/[sech(theta) tanh(theta)] but then everything cancels and we just have the integral of dtheta do we not?
latentcorpse said:
ok
Yes! :biggrin:
And the integral of dtheta is … ? :smile:
yeah but the integral of dtheta is theta
and that's equal to my right hand side of sqrt(Mgh/A) t
but if u look back to my first post that's not the solution i was aiming for
we're trying to get
sec(theta) = 1 + sech(sqrt(Mgh/A)t)
actually might be able to do a part without you! yay!
is this because if we take sech of both sides
but then sech(theta) = y = sec(theta) -1 and so it all rearranges
fantastic!
cheers for all your help m8!
legend!
we're trying to get
D'oh! :smile:
That's a different theta! :biggrin:
Try it with phi instead of theta … :wink:
EDIT: ah … you beat me to it … well done! :smile:
Hi there!
Here's my solution:
[tex](\frac{dx}{dt})^2=\frac{mgh}{A}(2x-1)(1-x)^2[/tex]
[tex]\frac{dx}{dt}=\sqrt{\frac{mgh}{A}(2x-1)(1-x)^2}[/tex]
[tex]\frac{dx}{dt}=(1-x)\sqrt{\frac{mgh}{A}(2x-1)}[/tex]
[tex]\frac{mgh}{A}=K[/tex]
[tex]\frac{dx}{(1-x)\sqrt{K(2x-1)}}=dt[/tex]
[tex]\displaystyle{\frac{1}{\sqrt{K}}\int\frac{dx}{(1-x)\sqrt{2x-1}}}=\displaystyle{\int}dt[/tex]
[tex]2x-1=z^2 <=> x=\frac{z^2+1}{2}[/tex]
[tex]2dx=2zdz <=> dx=zdz[/tex]
[tex]\displaystyle{\int}\frac{1}{(1-x)\sqrt{2x-1}} dx}=\displaystyle{\int}\frac{z}{(1-\frac{z^2+1}{2})z} dz=\displaystyle{2\int}\frac{1}{1-z^2} dz=\displaystyle{2\int}(\frac{1}{2(1-z)}-\frac{1}{2(1+z)}) dz=\displaystyle{\int}(\frac{1}{(1-z)}-\frac{1}{(1+z)}) dz=\ln{\frac{1-z}{1+z}[/tex]
[tex]z=\sqrt{2x-1}[/tex]
[tex]\ln{\frac{1-z}{1+z}=\ln{\frac{\sqrt{2x-2}}{\sqrt{2x}}=\ln\sqrt{\frac{2-2x}{2x}}=\displaystyle{\frac{1}{2}}\ln{2\frac{1-x}{x}}=\displaystyle{\frac{1}{2}}\ln{\frac{1-x}{x}}+c[/tex]
[tex]\frac{1}{2\sqrt{K}}\ln{\frac{1-x}{x}}+c=t[/tex]
[tex]\ln{\frac{1-x}{x}}=2\sqrt{K}(t-c)[/tex]
[tex]\displaystyle{\frac{1-x}{x}}=e^{2\sqrt{K}(t-c)}[/tex]
[tex]1-x=xe^{2\sqrt{K}(t-c)}[/tex]
[tex]x(1+e^{2\sqrt{K}(t-c)})=1[/tex]
[tex]x=\displaystyle{\frac{1}{1+e^{2\sqrt{K}(t-c)}}[/tex]
[tex]\cos{\theta}=\displaystyle{\frac{1}{1+e^{2\sqrt{K}(t-c)}}[/tex]
[tex]\sec{\theta}=1+e^{2\sqrt{K}(t-c)}[/tex]
[tex]\sec{\theta}=1+e^{2\sqrt{\frac{mgh}{A}}(t-c)}[/tex]
which is very similar to the solution given :) - s.o. has to prove the last term
If s.o. finds a mistake in it, I would be glad to see where it is :)
