Solving arctan(a²) - arctan(a) = 0.22 for a > 0
15 replies · 3K views · last reply
planauts
Find the values of a > 0, such that [tex]\int_{a }^{a^2} \frac{1}{1+x^2} dx = 0.22[/tex]
I integrated it and got:
[tex]arctan(a^2) - arctan(a) = 0.22[/tex]
I am stuck after this, how would I solve this :-/
Thanks
[tex]a^2 - a - tan(0.22) = 0[/tex]
I got 1.188 and -0.188
The correct answer is a = 2.04, 2.62
You might want to look up (or prove) the correct identity for [tex]\tan (A-B)[/tex].
I don't think that the tangent is the problem. I think my equation is wrong for some reason. Because when I graphed it the points don't make sense.
Do you see anything wrong with my math (integrating 1/(1+x^2) etc.)?
bigubau said:
The integration is ok. The trigonometry is the issue.
Then why doesn't the answer from the key work in the equation :-/
Are you using degrees instead of radians?
Let's try it with 2.04
Equation proofing is: arctan (2.04^2) = 76.488 deg. arctan 2.04 = 63.886 deg. Difference is 13.602 degrees = 0.23 radians.
So it's correct. The other solution can be checked for accuracy in the same manner.
You are saying that [tex]arctan(a^2) - arctan(a) = 0.22[/tex] is the correct equation.
So that's good. But now the problem is manipulating the equation to get the value of a.
How would I do that?
You said:
bigubau said:
Just apply <tangent> on both sides of your equation, use some trigonometry and see what you get
I think that is where I made the mistake...I have to apply <tangent> to the whole "left hand" side as a one. I split the tangent and distributed it. I don't think that is allowed.
So if I change it: [tex]tan[arctan(a^2) - arctan(a)] = tan(0.22)[/tex]
Is this what fzero meant?
Equation: tan(θ1 + θ2) = e1/(e0 − e2) = (x1 + x2)/(1 − x1x2) = (tan θ1 + tan θ2)/(1 − tan θ1 tan θ2).
[tex]\frac{a^2 - a}{1 - a^2 * a} = \frac{a^2 - a}{1 - a^3} = 0.22[/tex]
[tex]a^2 - a = 0.22 (1 - a^3)[/tex]
[tex]0 = 0.22 - 0.22 a^3 - a^2 + a[/tex]
I got a = 1 OR a = -5.3588 OR a = -0.2866
Trigonometric identity for the tangent of a sum: tan(θ1 + θ2) = e1/(e0 − e2) = (x1 + x2)/(1 − x1x2) = (tan θ1 + tan θ2)/(1 − tan θ1 tan θ2).
Yes but
[tex]\tan(\theta_1 - \theta_2 ) = \frac{\tan \theta_1 - \tan\theta_2}{1 + \tan \theta_1 \tan\theta_2},[/tex]
so you should find
[tex]\frac{a^2 - a}{1 \mathbf{+} a^2 * a} = \frac{a^2 - a}{1 \mathbf{+} a^3} = 0.22[/tex]
fzero said:
Yes but
so you should find
I got -0.184556093 and 1.946862606 = a, which still isn't right :(
fzero said:
Yes but
so you should find
There's still a little mistake there. You are taking tangent value on both sides, remember? :)
So, it should read something like this:
[tex]\tan \left( \arctan(a ^ 2) - \arctan(a) \right) = \tan (0.22)[/tex]
[tex]\Leftrightarrow \frac{a ^ 2 - a}{1 + a ^ 3} = \tan (0.22)[/tex].
Can you take it from here? :)
And, by the way, the book seems to have missed one possible value for a.
Oh my god! Thank you so much. I don't know why I wasn't seeing this...
I got 2.61737, 2.0416455 AND -0.223619421 as the roots.
Thanks to everyone who helped me, especially fzero :)
Yup, looks good to me.
However, since the problem just asks for positive values of a (a > 0), so you don't need to take a = -0.223619421 into consideration.
