Solving Bernoulli Equation: Confirm Results and Identify Error
Saladsamurai
I have solved the following Bernoulli equation by letting Z = y1 - 2:
xy' - 2y = x3y2. I obtained the solution
y = 5/(5c1 - x5)
which Wolfram Alpha has confirmed.
From this result, I have obtained y' to be
y' = 25x4/(5c1 - x5)2
The problem is when I go to check the solution by plugging into DE:
x*25x4/(5c1 - x5)2 - 2*5/(5c1 - x5)
[tex]= \frac{25x^4}{(5c_1 - x^5)^2} - \frac{10}{5c_1 - x^5} = \frac{25x^4}{(5c_1 - x^5)^2} - \frac{10*(5c_1 - x^5)}{(5c_1 - x^5)^2}[/tex]
which will never equal the right hand side of the original equation:
[tex]x^3y^2 = x^3\frac{25}{(5c_1 - x^5)^2}[/tex]Anyone seeing where I am messing this up?
thanks.
Hello fellow engineer ,
First of all your y(x) and wolframs y(x) are not the same function.
You are missing an [tex]x^{2}[/tex] term.
Ahhh...yes. Thanks! So let's try this again...
The solution to xy' - 2y = x3y2 is given by
[tex]y(x) = \frac{5x^2}{5c - x^5} = 5x^2(5c - x^5)^{-1}[/tex]
[tex]\Rightarrow y'(x) = (5x^2)\cdot[(-1)(5c - x^5)^{-2}(-5x^4)] + ((5c - x^5)^{-1})\cdot[10x][/tex]
[tex]\Rightarrow y'(x) = \frac{25x^6}{(5c-x^5)^2}+\frac{10x}{5c-x^5}[/tex]
[tex]\Rightarrow y'(x) = \frac{25x^6+(5c - x^5)(10x)}{(5c - x^5)^2}[/tex]
Plugging the result back into original DE we have
[tex]\frac{25x^7+(5c - x^5)(10x^2)}{(5c - x^5)^2} - 2*\frac{5x^2}{5c - x^5}=<br /> \frac{25x^7+(5c - x^5)(10x^2)}{(5c - x^5)^2} -\frac{(5c - x^5)(10x^2)}{(5c - x^5)^2} = \frac{25x^7}{(5c - x^5)^2} = A[/tex]
From the right side of original DE we know that
[tex]A' = x^3y^2 = \frac{(x^3)(25*x^4)}{(5c - x^5)^2} =\frac{25x^7}{(5c - x^5)^2}[/tex]
Thus, A = A' and we must have the solution.
Thanks for catching that error! :smile:
