Solving (dy/dx)(x³ - 12y) = x² more efficiently
  • Level: Graduate
  • Thread starter Thread starter scorpion990
    Ode
10 replies · 4K views · last reply
scorpion990
[tex]\frac{dy}{dx}[/tex][x^3-12y]=x^2
That ODE took me a little while to solve... I had to switch from dy/dx to dx/dy, do a Bernoulli substitution, two applications of integration by parts, and then some algebraic manipulations in order to solve it.
The final result?
y = (x^3-4)/12
This really simple equation which satisfies the ODE leads me to believe that there is an easier method for solving this... A few of these might appear on my final tomorrow, and I don't want to spend all of that time if there is an easier method.
Thanks!
Whilst this reply will come a little too late for your final, it may still be useful. Notice that if we assume that [itex]x\neq0[/itex] we may write,
[tex]\frac{dy}{dx} - \frac{12}{x^3}y=\frac{1}{x}[/tex]
Which is a much easier to solve.
Ya... The derivative was supposed to be distributed.
Looking at the de, if you were to power expand y (heck you could even Laurent expand it) in order to preserve the right hand side y would have to be cubic, that is the powers can't be less than 0 nor can they be greater than 3.
So say there exists a,b,c,d such that [tex]y = ax^3 + bx^2 + cx + d[/tex] then we have
[tex]\frac{dy}{dx}(x^3-12y) = (3 ax^2 + 2bx + c)[(1 - 12a)x^3 -12bx^2-12cx-12d][/tex]
but that has to equal x^2 so the x^5 term must go away
[tex] 3a(1-12a)=0[/tex]
and clearly a is not zero so [tex]a=1/12[/tex].
The x^4 term must also go away
[tex] -12b(3a) = 0[/tex]
and we know a is not zero so that means that [tex]b=0[/tex].
Let's restate the equation again
[tex] (\frac{1}{4}x^2+c)(-12cx-12d)=x^2[/tex]
The x^3 term goes away so
[tex] 3c=0[/tex]
or [tex]c=0[/tex].
Alright finally the x^2 term should have a coefficient of 1 so
[tex] -3d=1[/tex]
or [tex]d=-1/3[/tex].
And we have the solution [tex]y=\frac{1}{12}x^3-\frac{1}{3}[/tex]
This is not a simpler method to solve it, but I think it shows more clearly why the solution is so simple.
Hi scorpion990! :smile:
The way I'd do it is to assume that y is a polynomial in x.
If its highest term is x^n, then you start with nx^(n-1)[x^3 - 12x^n], so the highest terms are 3+n-1 and/or n+n-1, and so … :smile:
Defennder said:
What happened to the dy/dx term in your [tex]- \frac{12}{x^3} y[/tex]?
Sorry guys, I misread the parenthesise, my bad.
Make it exact?
Why wouldn't you make it exact first.
[tex](x^3 - 12y)dy + (-x^2)dx = 0[/tex]
By inspection one can find [itex]e^\left-3y\right[/itex] makes this exact.
[tex]e^\left-3y\right\right((x^3 - 12y)dy + e^\left-3y\right\right((-x^2)dx = 0[/tex]
[tex]\smallint e^\left-3y\right\right((x^3 - 12y)dy[/tex]
[tex]\smallint e^\left-3y\right\right((-x^2)dx[/tex]
After the one integration by parts that is required, you end up with:
[tex]C = \frac{e^\left-3y\right}{3}(4 - x^3 + 12y)[/tex]
I guess you have an initial condition that tells you that C is zero.
This may or may not be considered quicker, but it was the only way I remembered after taking DE 10+ years ago. :)
Keep these problems coming. I'm going to go back to school and get a master's, assuming the wife let's me. :)
Well I certainly couldn't see that would have worked! I mean, how did you know that some integrating factor existed which could make it exact?
Nice work. Everyone else has found a particular solution. You found the general solution.
When I took DE in college, I would always look to make it exact first. Since the @/@y of the second term is zero and the @/@x of the first term is in terms of x only, you know that the integrating factor is probably a function of y only. You end up with
[tex]F(y) = -F'(y)/3[/tex]
