Solving e^x + e^-x = 6
  • Thread starter Philoctetes3
    Exponential
3 replies · 3K views · last reply
Philoctetes3
I just want to make sure that I have this in the correct order. The book I have is very unclear.
e^x + e^-x = 6
e^x + 1/e^x = 6
e^2x + 1 = 6e^x
e^2x/e^x + 1 = 6
x = ln 6
Thanks.
You've made a mistake. The fourth line doesn't follow from the third. It looks like you tried to divide by e^x (which is actually just undoing what you did in going from line 2 to 3), but you forgot to divide the 1 by e^x.
What you should do is rearrange your third line so that it looks like
e^(2x) - 6e^x + 1 = 0.
Does this look like a familar sort of equation? (If not, let y = e^x. Then does it look familar?)
Thanks a lot. I thought something looked off. The thing that worried me is that the answer that I got is quite approximate, and I wanted to make sure that I was doing the process correctly, which I wasn't.
Then after this I would simply do the U form of the quadratic, correct?
Yes, the equation is quadratic in form, so a substitution will make it a quadratic, which you can solve using the quadratic formula.
