Solving Electric Magnetism Problems: Forces, Fields, Potentials, Work
The discussion focuses on solving electric magnetism problems involving two charges of 6 and 10 microcoulombs, 10 cm apart. The calculated force of repulsion is 53.94 N, and the electric field midway between the charges is initially calculated as 3.6 x 10^6 N/C, though there is uncertainty about whether to add or subtract the individual electric fields. For the potential at the midpoint, the user calculated 10.78 N·m but confused potential energy with potential, leading to questions about the correct approach for calculating work done in bringing an electron from far away to the midpoint. Clarifications were provided regarding the measurement of distance and the relationship between potential energy and work, ultimately aiding the user in understanding the concepts better.
brains
I need some help figuring #2 problem out.
1. two charges of 6 microcoulombs and 10 microcoulombs are 10cm apart. Calculate their force of repulsion. Calculate the electric field midway between them.
2. For the charges in question 1 calculate the potential midway between them. Calculate the work to bring an electron from far away to midway between them.
So for the first question I used F= k |q1||q2|/r^2 for the second part of the first question i did E = k |q|/r^2
i calculated that the force would be 53.94N
As for the electric midway I calculate it to 3.6 x 10^6 N/c Although I am not sure if i was supposed to add or subtract E1 and E2. So what i did is that i subtracted. But I am not entirely sure if that is my correct answer My work:
E1 = 8.99x 10^9 N*m^2/c^2 x |6 x10^-6 C|/(0.1m)^2
E1 = 5.39 x 10^6 N/c is my answer for E1
E2 = 8.99 x 10^9 N*m^2/c^2 x |10 x 10^-6C|/(0.1m)^2
E2 = 8.99 x 10 ^6 N/C
Then i did E = 8.99 x 10^6 N/C - 5.39 X 10^6 N/C
And I got 3.6 x 10^6 N/C however like i said before I am not exactly sure if this was the correct approach to get the electric field midwayFor the second question
I used this equation (U= k (q0)(q)/r ---> k being 8.99 x10^9n.m^2/c^2 for part of the 1st question in question 2 that asks for potential midway and got an answer of U= 10.78 N M
however when they asked me for the work in question two i assumed I should have used -W=q0Ed
but i don't know what numbers I would use for this equation. Would the correct way of going about it be
doing -W=(1.60 x 10^-19C)(8.99 x 10^6 N/C - 5.39 X 10^6 N/C)(0.1m) or is this wrong?
IF someone could please point me in the right direction and check if I've done these steps correctly it would be helpful. Thank you in advance.
My work:
Hey there!
Yep. That's right.
My work:
You're almost correct here - I'd say to take a look at your value for r again. As in, what are you measuring r to be again?
As for both parts of the second question:
...i assumed I should have used -W=q0Ed
The formula for U is for electrical potential energy, not the potential. But - there's a relationship between the two quantities, as well as one between W and U. Once you find those out, you're good to go.
Likes 1 person
Well I take the idea it's 10cm i converted that into 0.1m. Um I am guessing since they are asking me to calculate the electron from far away to midway. I would only take into account half of the original distance right?
In regards to the Electric field problem, the question asks for the electric field at the midway point between the two charges. A radius of 10 cm here would imply that the point in question is at either charge.
With respect to the Potential Energy, yes. To be more technical, it's ΔU = Uf - U0, and if you use an r = ∞ for Uf, that expression becomes just -U0.
Sorry for the late reply and thank you very much i finally understood it :D.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
