How Do I Solve Equations with e and ln?
  • Thread starter Thread starter winston2020
    Solving equations
To solve equations involving e and ln, it's important to correctly identify the function and its derivatives. In the case of f(t) = e^(-9t), the second derivative is 81e^(-9t), which is always positive, indicating that the function is concave upward for all t. Setting the first derivative to zero is necessary to find stationary points, but purely exponential functions like e^(-9t) do not have stationary points. Instead, the concavity is determined by the sign of the second derivative at specific t values. Understanding these principles is crucial for analyzing the behavior of exponential functions.
winston2020
For example, let's say that f(x) = e^(-9t)
Once I've found the second derivative, I equate it to zero in order to determine concavity, but I don't know how to solve it after that :rolleyes:
I'm just having a hard time solving with the ln or whatever you have to do..:confused:
Are you trying to solve the equation to find t=something? Or are you tring to do something else? Is t a function of x? Could you clarify your problem please because at the moment it makes no sense whatsoever.
If you're trying to determine concavity, you need to figure out when the 2nd derivative is positive, negative, or zero. Just setting it to zero will tell you where the inflection points are (neither concave up nor down), and if there are no such points then you'll get "no solution" when you do this.
sorry, what i meant was set the first derivative to zero, and solve for t. Then use the t value to solve for the second derivative.
(The function should have been f(t) not f(x))
Okay.
Plug the value of t you have (from setting 1st derivative = 0) into the 2nd derivative.
Is the result positive, negative, or zero?
Err, just one problem with that: et has no roots. A purely exponential function has no stationary points and therefore it's first derviative is never zero. However, functions involving expoentials can have stationary points. For example,
y(x) = e^x-x
y^\prime(x) = e^x-1
Hence, y(x) has a stationary point when,
e^x = 1 \Rightarrow x=0
No, you don't "equate the second derivative to zero in order to determin concavity".
The concavity of f(t) at a particular t depends upon the sign of f" at that particular t.
The second derivative of e^(-9t) is 81e^(-9t) and , as pointed out by others, that is never equal to 0. At t= 0, it is 81> 0. Since 81e^(-9t) is continuous and never equal to 0, it is always positive and so f(t)= e^(-9t) is concave upward for all t.
Thanks for all your help everyone :smile:
  • · Replies 26 ·
