Solving Euler's Method: Accuracy of y_100 = 3.1515
The discussion revolves around the application of Euler's method to approximate the value of a function related to pi, specifically evaluating y_100 with a step size of h = 0.01. Participants express concerns about the accuracy of their results and the implications of the problem's instructions regarding the convergence of the method.
  • Participants discuss the accuracy of Euler's method and its limitations, particularly in relation to approximating pi. Questions arise about the meaning of using different values of h while keeping n constant, and whether this aligns with the problem's requirements. Some participants explore the convergence behavior of the method with varying step sizes and the implications of round-off errors.
The discussion is ongoing, with participants sharing their attempts and questioning the clarity of the problem statement. Some guidance has been offered regarding the relationship between step size and the number of steps, but no consensus has been reached on the best approach to take.
Participants note that the problem is significant for their final grade and is due soon, adding pressure to resolve the uncertainties. There is mention of potential issues with the wording of the question and how it may lead to confusion regarding the expected method of solution.
bl4ke360
http://img853.imageshack.us/img853/5578/euler.png
y_(n+1)=y_n+f(x_n,y_n)h
With n = 100 and step size h = 0.01, I got y_100 = 3.1515
I don't see how this is right, because the directions imply that it's supposed to be accurate to pi within 4 decimal places, but this last value is higher than pi. Also what does it mean by using different values of h, and still keeping n = 100? That doesn't make any sense because then it wouldn't evaluate up to y(1) = pi.
Euler's method isn't all that accurate. It doesn't give you pi that accurately with 100 steps as you found. I don't know what they mean by using different values of h either. That won't give you an approximation to pi, it will give you an approximation to 4*arctan(h*n). May just be a badly written question. They might just mean how small does h have to be to give you a good appoximation to pi after 1/h steps.
This problem is 10% of my final grade (and due tomorrow) so I want to make sure I'm doing it correctly. From the directions it says it's supposed to converge, but it doesn't look like it does unless I'm missing something. It converges at around 6.299, with n = 100,000. I also verified it by solving the function directly after solving for it from the D.E. which is y(x)=4arctan(x). I don't see what I'm supposed to do from here.
Euler's method will converge if you use a small enough step size. Did you use n=100000 with h=1/(100000)? Though round-off errors and stability might start taking their toll. I'm not exactly sure what it expects you to do from the wording either.
I see what you mean now, but since I only have to go to n=100 I guess I don't have to worry about that here. But I don't know if I'm supposed to change the step size partially into it, or do a separate run of euler's method with a different step size. Since the directions says to use only one table, I would assume the I have to change the step size before n reaches 100, but that doesn't make any sense to me.
That's the problem with the question. You won't get to x=1 and pi if you only change the step size and not n.
