Solving first and second order ODEs with Laplace transforms
109 replies · 12K views · last reply
y(t)=(1/2)t^2(e^-t) + 4t(e^-2t)
This is the answer. don't substitute anything into anything.
Excellent.
So
[tex]y(t) = \frac{1}{2}t^2 e^{-t} + 4te^{-2t}[/tex]
Tomorrow, I'll start (c), if that's okay?
TFM
Okay, so:
(c):
[tex]y'' + y = sin(t), y_0 = 1, y_0' = 0[/tex]
L(y(t)) = Y
L(y'(t)) = sL(y(t)) - y(0)
L(y''(t)) = sL(y'(t))-y'(0) = s^2(L(y(t))-sy(0)-y'(0)
there is no y',
[tex]L(y(t)) = Y[/tex]
[tex]L(y'(t)) = sL(y(t)) - 1[/tex]
[tex]L(y''(t)) = sL(y'(t))-0 = s^2(L(y(t))-sy(0)-y'(0)[/tex]
and for the sin(t)
[tex]sin(\alpha t) = \frac{\alpha}{p^2 + \alpha^2}[/tex]
since alpha = 1:
[tex]sin(t) = \frac{1}{p^2 + 1}[/tex]
Is this okay, I am not quite sure because the lack of y'
TFM
Okay so:
[tex]L(y''(t)) = s^2(L(y(t))-sy(0)[/tex]
So now I substitute these into the original equation:
[tex]y'' + y = sin(t)[/tex]
[tex]s^2(L(y(t))-sy(0) + Y = \frac{1}{p^2 + 1}[/tex]
Is this okay? Do I substitute y(0) into sy(0), or is there another value/leave it alone?
TFM
That's fine
substitute y(0) and also substitue the value L(y(t))
Okay, so
[tex]s^2(Y)-1 + Y = \frac{1}{p^2 + 1}[/tex]
[tex]Ys^2 + Y - 1 = \frac{1}{p^2 + 1}[/tex]
Now I need to make the Y the subject:
[tex]Ys^2 + Y = \frac{1}{p^2 + 1} + 1[/tex]
factorise out
[tex]Y(s^2 + 1) = \frac{1}{p^2 + 1} + 1[/tex]
divide through:
[tex]Y = \frac{\frac{1}{p^2 + 1} + 1}{s^2 + 1}[/tex]
Now I need to find the inverse.
Firstly, split it up into two fractions:
[tex]Y = \frac{\frac{1}{p^2 + 1}}{s^2 + 1} + \frac{1}{s^2 + 1}[/tex]
Does this look okay?
TFM
in ur second line, you have: s^y-1+y=1/(s^2+1)
the -1 on the left hand side should be -s (since you have:L(y'')=s(sy-1)
and remember: s is p so don't put both...choose one of them :)
Okay so:
[tex]Ys^2 + sY - 1 = \frac{1}{s^2 + 1}[/tex]
Does this look okay now?
TFM
you should have:
Ys^2 - s + Y=1/(s^2+1)
i think you made a mistake while substituting.
Okay, back a bit originally:
[tex]s^2(L(y(t))-sy(0) + Y = \frac{1}{s^2 + 1}[/tex]
y(0) = 1
L(y(t)) = Y
put these in:
[tex]s^2(Y) - 1 + Y = \frac{1}{s^2 + 1}[/tex]
goes to:
[tex]Ys^2 - 1 + Y = \frac{1}{s^2 + 1}[/tex]
I still have a minus one where there should be a minus s.?
TFM
y''+y'=sint
L(y(t))=Y
L(y'(t)=sL(y(t))-y(0)=sY-1
L(y''(t))=sL(y'(t))-y'(0)=s(sy-1)-0
=s^2Y-s
substitute this into the equation: y''+y'=sint
(s^2)Y-s+Y=1/(s^2+1)
sara_87 said:
y''+y'=sint
L(y(t))=Y
=s^2Y-s
Isn't the equation:
though, not
[tex]y'' + y' = sin(t)[/tex]
TFM
yep that's what i meant.
substitute this into the equation: y''+y=sint
Okay so:
[tex] y''+ y = sin(t) [/tex]
L(y(t))=Y
L(y''(t))= s(sy-1)-0
insert into equation:
[tex]s(sy - 1)+ Y = sin(t)[/tex]
multiply out:
[tex]s^2y - s+ Y = sin(t)[/tex]
sin(t)= 1/(s^2+1)
[tex]s^2Y - s + Y = \frac{1}{s^2+1}[/tex]
Is this okay? If so I now have to rearrange to find Y
[tex]s^2Y + Y = \frac{1}{s^2+1} + S[/tex]
[tex]Y(s^2 + 1) = \frac{1}{s^2+1} + S[/tex]
giving:
[tex]Y = \frac{\frac{1}{s^2+1} + S}{s^2 + 1}[/tex]
split the fraction:
[tex]Y = \frac{\frac{1}{s^2+1}}{s^2 + 1} + \frac{S}{s^2 + 1}[/tex]
Does this look better?
TFM
much better :)
so now you have:
Y=1/[((s^2)+1)^2] + s/((s^2)+1)
now, the inverse laplace of s/(s^2 + 1) should be in you tables (can you find it?) and so, what are you going to do about the first fraction 1/[((s^2)+1)^2] ?
the inverse of:
[tex]\frac{S}{s^2 + 1} is cos(t)[/tex]
for:
[tex]\frac{1}{((s^2)+1)^2}[/tex],
I assume the first Shift Theroem is required?
TFM
no first shift theorem...why do you assume that??
1/[((s^2)+1)^2] can be split into 1/[(s^2)+1] * 1/[(s^2)+1]
convolution says that if you have the product of two functions, F(s)G(s), the inverse laplace can be evaluated by doing: first find the inverse laplace of F(s) and G(s) (call them F(t) and G(t) respectively) then carry out:
integral (with limits 0 to t) of (F(u)G(t-u)) du
the value of the integral gives you the inverse of the laplce F(s)G(s).
so in you case, you have: F(s)=1/(s^2+1) and G(s)=1/(s^2+1)
what's the inverse of both of them (surely they give the same inverse) ?
so we have:
the inverse of both is:
sin(t)
All right so far?
TFM
yep that's right, so now evaluate the integral with limits 0 to t of:
sin(u)sin(t-u) du
you might wana remember the formula:
sin(A)sin(B)=1/2(cos(A-B)-cos(A+B))
and in this case, A=u and B=t-u
you have been taught convolution...right?
Okay so:
A=u and B=t-u
sin(u)sin(t - u)=1/2(cos(u-(t - u))-cos(u+(t - u)))
this would go to:
1/2(cos(2u-t)-cos(t))
Integrate from 0 to t
[tex]\int^t_0 1/2(cos(2u-t)-cos(t)) du[/tex]
Take the half outside:
[tex]\frac{1}{2}\int^t_0 cos(2u-t)-cos(t) du[/tex]
integrating becomes:
[tex]\frac{1}{2} \left[ sin(2u - t) - sin(t)\right]^t_0[/tex]
okay so far?
TFM
Hmm,
wells, cos(t) has no values of u, so can be assumed to be a constant, so would it be cos(t)*u ?
TFM
The integral of cos(u) is sin(u)
The integral of cos(2u) is 1/2sin(2u)
So would that make the integral of:
cos(2u - t) = 1/2sin(2u - t) ?
TFM
good
so evaluate with limits t and 0 and don't forget the 1/2 outside the bracket.
Okay so now:
[tex]\frac{1}{2} \left[ 1/2sin(2u - t) - cos(t)u \right]^t_0[/tex]
so this goes to:
[tex]\frac{1}{2} \left[ (1/2sin(2t - t) - cos(t)t) - (1/2sin(2(0) - t) - cos(t)0) \right][/tex]
and:
[tex]\frac{1}{2} \left[ (1/2sin(t) - cos(t^2) - (1/2sin(-t)\right][/tex]
TFM
the second to last step is:
1/2(1/2sin(2t-t) - tcos(t) - 1/2(sin(-t)) - 0cost)
the last step is not ok... remember: sint is odd function so sin(-t)=-sin(t)
so...how would you write the last step?
okay so:
[tex]\frac{1}{2} \left[ (1/2sin(2t - t) - tcos(t)) - (1/2sin(2(0) - t) - cos(t)0) \right][/tex]
[tex]\frac{1}{2} \left[ (1/2sin(2t - t) - tcos(t)) - (1/2sin(-t)) \right][/tex]
this is the same as:
[tex]\frac{1}{2} \left[ (1/2sin(2t - t) - tcos(t)) + (1/2sin(t)) \right][/tex]
Is this better?
TFM
