Second Order ODE Using Laplace Transforms
3 replies · 3K views · last reply
jazznaz
Little homework problem that I'm beating myself up over...
Solve:
[tex]xy'' - 2y' + xy = -2\cos x[/tex]
Using the method of Laplace transforms...
So I do some jiggling and get to:
[tex](1+s^{2})\frac{dF}{ds}+4sF(s) = \frac{2s}{s^{2} + 1}[/tex]
To which I find the following solution:
[tex]F(s) = \frac{C}{(1 + s^{2})^{2}} + \frac{s^{2}}{(1 + s^{2})^{2}}[/tex]
But I'm supposed to get to:
[tex]F(s) = \frac{C}{(1 + s^{2})^{2}} + \frac{s^{2}-1}{(1 + s^{2})^{2}}[/tex]
But the method I'm using to solve the first order ODE (variation of parameters/constants) won't seem to lead to the answer I need. It almost looks as though I should include an aribtrary constant where they're expecting me to get -1, but it seems that any constant value will be a solution to the first order DE obtained after applying the transform. So I don't really understand how they've deduced that it should be -1...
We've been given the answer to the problem,
[tex]y = \frac{C}{2}(\sin x - x\cos x) + x\cos x[/tex]
Where the result is obtained easily using a table of Laplace Transforms.
Those are equivalent. To see this, start from the second expression.
[tex]F(s) = \frac{C+s^2-1}{(1 + s^{2})^{2}}[/tex]
[tex]F(s) = \frac{s^2+(C-1)}{(1 + s^{2})^{2}}[/tex]
Since C is an arbitrary constant, so is C-1.
So the justification is altering the constant to give a nice form for the inverse Laplace transform?
Thanks very much!
